Write image to eMMC - Pinebook 11.6"
Ok. This has probably been done to death, but I'm trying to get my head around writing a bootable image to the eMMC.
As far as I can tell there are two steps.
1 Download an image and write it to an SD card, and boot the Pinebook from it.
2 After booting, download another image (same or different- but basically the one you want on the eMMC) then use dd to write to of=/dev/mmcblk1
Then power off, remove SD card, power on. The Pinebook should boot from the image that was written in step 2. Is that basically it?
I just got the 1080p image from here:
https://wiki.pine64.org/wiki/Pinebook_So...Neon_Image
I flashed it to my SD card using dd, and it boots. I've "set it up" but I realise that that has only affected the SD card image. My guess is I have to dd the image again (as I said) and then reboot and set it up (again).
Thanks.
Write image to eMMC - Pinebook 11.6" - by irongarment - 01-01-2022, 10:27 PM
  DietPi OS for Pinebook MichaIng 3 5,371 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 60,916 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 892 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 685 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,577 04-13-2023, 01:09 PM
Rainbow Customised (encrypted) eMMC installation using Anarsoul's ArchLinux Blutkoete 24 34,530 05-02-2022, 12:59 PM
Last Post: thunderweasel
  Stock Debian on original Pinebook moonwalkers 1 3,218 01-29-2022, 10:37 PM
Last Post: cel
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,242 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,806 01-20-2021, 11:18 AM
  Kali on SD does not Detect EMMC marianobilli 1 3,302 01-07-2021, 06:56 PM
Last Post: evilbunny
