Updated stock Manjaro, now won't boot (brick?)
(02-17-2022, 10:41 AM)pineymousepad Wrote: Is there a proper guide somewhere someone would so kindly please point me to on how to "boot with SD Card"? Is the eMMC adapter required for this?
Seriously I just did an pacman update and it bricked within first week of opening the PBP from the mail.... Wtf? If this system is so vulnerable to bricking from a simple update shouldn't have this shipped  with the eMMC adapter??
I assume you are using manjaro.....an update installs a new kernel, BUT only copies the uboot files to /boot
This is NOT installed, you have to do the dd commands to put the uboot files in 1st 16M (idbloader.img, uboot.itb)
So, on emmc, it still has 'old' uboot files, since emmc has priority in initial search these are still what are being used
(not any uboot files on SD)
After uboot loads the search priority changes, a bootable SD ahead of emmc
So, any SD that booted before will still likely boot
You do have a backup SD boot card??? If not, you should
If the old extlinux.conf was renamed to *.bak, then do some re-nameing to use previous kernel, previous extlinux
or else edit new one
NOTE: if you have any other SBC, do not, by accident put a uSD in that will boot, say A64, it will NOT work,
and it WILL soft brick and WILL need a hard reset, hold power button 20+s (from personal experience)
No emmc adapter required, just expand,write suitable image to SD card (I reccomend mrfixit)
ie,,, xzcat some.image.xz |dd of=/dev/sd-card bs=1M....... (zcat if it is gz image)
RE: Updated stock Manjaro, now won't boot (brick?) - by wdt - 02-17-2022, 11:57 AM
  Manjaro versions bad and good gilwood 0 301 02-12-2024, 05:03 PM
Last Post: gilwood
  uboot wont boot to SD card after upgrade jbradley419 7 994 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 332 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,393 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 781 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 647 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,276 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,998 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 830 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 2,036 06-14-2023, 07:20 AM
