Call waiting issue
#19
(04-10-2022, 12:11 PM)alaraajavamma Wrote:
(01-27-2022, 07:00 PM)kmsgli Wrote: So I revisited this and got it to work but it is not a great outcome. I still wanted to post how-to in case this can help someone down the road...
Hello!
Is this solution working for you with VoLTE calls?
My carrier (DNA, Finland) told me this:
This and USSD codes are only for 3G or 2G calls.
If Call waiting is disabled and you are in 2G or 3G (DNA) the call does not end up to the phone at all if the line is busy
In VoLTE (DNA) call will go trough but it can be stop with phone own setups - in this case it should be Gnome Calls but as we know it is not ideally working currently Smile
how the user inteface is built in pinephone o.s., i recommend disabling call waiting altogether.
i'm not sure though, but call waiting works with volte, if device has user interface for it. but i haven't used call waiting for years. so, i don't know how well call waiting works with volte.
however, those special commands like call waiting, call forwarding, ussd and possible others do not (mostly) work on volte. they may (not) work on lte network, regardless is volte operational or not. still, when doing those commands, i recommend downgrading to gsm(2g) or umts(3g).
instructions on this thread is, how to disable call waiting until support for it is better.
Call waiting issue - by kmsgli - 12-08-2021, 07:42 PM
RE: Call waiting issue - by kmsgli - 12-11-2021, 03:39 PM
RE: Call waiting issue - by zetabeta - 12-11-2021, 05:53 PM
RE: Call waiting issue - by kmsgli - 12-14-2021, 08:17 PM
RE: Call waiting issue - by zetabeta - 12-14-2021, 11:50 PM
RE: Call waiting issue - by kmsgli - 12-15-2021, 05:07 PM
RE: Call waiting issue - by zetabeta - 12-16-2021, 01:12 AM
RE: Call waiting issue - by kmsgli - 12-17-2021, 07:01 PM
RE: Call waiting issue - by zetabeta - 12-19-2021, 01:19 PM
RE: Call waiting issue - by kmsgli - 12-23-2021, 01:01 PM
RE: Call waiting issue - by kmsgli - 12-25-2021, 01:36 PM
RE: Call waiting issue - by kmsgli - 01-27-2022, 07:00 PM
RE: Call waiting issue - by johns - 01-27-2022, 11:06 PM
RE: Call waiting issue - by kmsgli - 01-28-2022, 06:14 AM
RE: Call waiting issue - by alaraajavamma - 04-10-2022, 12:11 PM
RE: Call waiting issue - by kmsgli - 04-10-2022, 04:58 PM
RE: Call waiting issue - by zetabeta - 04-11-2022, 05:28 AM
RE: Call waiting issue - by alaraajavamma - 04-11-2022, 02:30 PM
RE: Call waiting issue - by devrtz - 06-01-2022, 11:05 AM
RE: Call waiting issue - by Zebulon Walton - 01-28-2022, 09:03 PM
RE: Call waiting issue - by kmsgli - 01-29-2022, 07:11 AM
RE: Call waiting issue - by alaraajavamma - 06-23-2022, 01:25 AM
RE: Call waiting issue - by kmsgli - 06-24-2022, 06:02 PM
  debugging issue realted to iso image wth extra data eror penguins_rule 3 411 04-23-2024, 03:15 AM
Last Post: tapirsurfeit
  systemic issue pinephone penguins_rule 3 490 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 1,867 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Internal Microphone issue during calls Viktor 6 2,630 03-31-2023, 08:58 AM
Last Post: Viktor
  Firefox issue with latest update Barugon 6 2,485 01-28-2023, 01:29 AM
Last Post: alaraajavamma
  Unable to hear caller or speak after answering a call danimations 5 4,088 11-01-2022, 02:06 PM
Last Post: X0X0X0X0X0
  Weird call... Eugo 3 2,058 09-15-2022, 11:20 PM
Last Post: Eugo
  New issue with phone calls kmsgli 13 6,916 08-15-2022, 01:45 PM
Last Post: Gon
  Pinephone craches after each call neithan76 2 1,649 07-29-2022, 11:47 AM
Last Post: Chief
  Can't call or receive calls PJK2012 3 2,974 04-26-2022, 03:05 PM
Last Post: PJK2012
