Wont charge when powered off, and update question
(12-06-2021, 07:26 PM)KC9UDX Wrote: It looks like you were first in the right place to find the proper firmware updater.  Mangaro nor any other operating system that I'm aware of will (nor should) do this.
Keep in mind that what you are doing to fix the touchpad is an actual firmware update, as in real firmware, not a software update a la Linux "firmware".
Uh.. So do you mean I should use "pbp-fwupdate" in place of "./updater" from the instructions in the github? What is the benefit of using it over the standard ./updater ? Tough crowd here, not much help, vague. Appreciate you atleast responding.
RE: Wont charge when powered off, and update question - by pineymousepad - 12-08-2021, 10:55 PM
  uboot wont boot to SD card after upgrade jbradley419 7 916 01-19-2024, 02:29 PM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,305 12-15-2023, 02:11 PM
  Newbie Question!! oniichann 3 938 10-26-2023, 07:09 AM
  After update, multiple problems, pinebook pro. jd50i 1 1,068 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 1,087 02-22-2023, 03:23 PM
Last Post: robocone
  GPIO breakout question pinus_pinea 0 690 01-17-2023, 06:13 AM
Last Post: pinus_pinea
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,365 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,440 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 2,032 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,129 05-10-2022, 01:52 AM
Last Post: diyagabriel
