Armbian on Quartz64
#26
(02-02-2022, 12:14 AM)balbes150 Wrote: There is no support for HDMI in the 5.10 kernel yet.
I believe that there is in 5.16 with VOP2 patches applied.
Source code is here https://gitlab.com/pgwipeout/linux-next/
By the way I have successfully installed Debian Buster on an eMMC quartz64 with the pgwipeout mainline kernel and it works beautifully, though I haven't yet tried HDMI out.
I am in the process of writing up instructions.
Essentially you do this:-
1. Partition your eMMC like this:-
https://wiki.pine64.org/wiki/Quartz64_In..._Linux_ARM
but be extremely careful about the "sdb" in the commands because if that's another drive in your desktop/laptop you are going to destroy the drive
2. Image this image to micro SD and boot:-
https://wiki.pine64.org/wiki/Quartz64#pg...uartz64_CI
it boots with a boot menu
With one of the options you can go to "debian installer"
Go through it all but at the partitioning menu select the root partition on the eMMC and install to that.
3. Reboot but on the boot menu select "recovery"
chroot into the eMMC and use dpkg to delete the kernel image packages.
exit chroot
Mount the boot partition on the eMMC and set up extlinux.conf and copy over the kernel and dtb file from the microSD card boot partition
these are only general instructions and I my intention is to write it up properly
Armbian on Quartz64 - by dieselnutjob - 11-12-2021, 07:21 AM
RE: Armbian on Quartz64 - by dieselnutjob - 11-12-2021, 12:23 PM
RE: Armbian on Quartz64 - by TRS-80 - 11-12-2021, 02:16 PM
RE: Armbian on Quartz64 - by dieselnutjob - 11-12-2021, 03:41 PM
RE: Armbian on Quartz64 - by dieselnutjob - 11-14-2021, 09:58 AM
RE: Armbian on Quartz64 - by dieselnutjob - 11-15-2021, 08:21 AM
RE: Armbian on Quartz64 - by TRS-80 - 11-16-2021, 07:29 AM
RE: Armbian on Quartz64 - by dieselnutjob - 11-16-2021, 10:03 AM
RE: Armbian on Quartz64 - by TRS-80 - 11-16-2021, 02:24 PM
RE: Armbian on Quartz64 - by balbes150 - 11-22-2021, 01:25 AM
RE: Armbian on Quartz64 - by tllim - 01-23-2022, 10:32 PM
RE: Armbian on Quartz64 - by dieselnutjob - 11-22-2021, 03:53 AM
RE: Armbian on Quartz64 - by balbes150 - 11-22-2021, 05:30 AM
RE: Armbian on Quartz64 - by dieselnutjob - 11-22-2021, 05:54 AM
RE: Armbian on Quartz64 - by balbes150 - 01-13-2022, 05:25 AM
RE: Armbian on Quartz64 - by mulimoen - 01-21-2022, 03:12 PM
RE: Armbian on Quartz64 - by balbes150 - 01-22-2022, 02:31 AM
RE: Armbian on Quartz64 - by mulimoen - 01-22-2022, 03:23 AM
RE: Armbian on Quartz64 - by balbes150 - 01-23-2022, 06:30 AM
RE: Armbian on Quartz64 - by balbes150 - 01-22-2022, 06:51 AM
RE: Armbian on Quartz64 - by mulimoen - 01-23-2022, 10:54 AM
RE: Armbian on Quartz64 - by balbes150 - 01-24-2022, 03:46 AM
RE: Armbian on Quartz64 - by shaggy013 - 02-01-2022, 01:31 PM
RE: Armbian on Quartz64 - by balbes150 - 02-02-2022, 12:14 AM
RE: Armbian on Quartz64 - by shaggy013 - 02-13-2022, 04:09 AM
RE: Armbian on Quartz64 - by shaggy013 - 02-06-2022, 08:09 AM
RE: Armbian on Quartz64 - by dieselnutjob - 02-06-2022, 08:15 AM
RE: Armbian on Quartz64 - by shaggy013 - 02-06-2022, 02:39 PM
RE: Armbian on Quartz64 - by dieselnutjob - 02-06-2022, 04:48 PM
RE: Armbian on Quartz64 - by mulimoen - 02-13-2022, 04:43 AM
RE: Armbian on Quartz64 - by shaggy013 - 02-13-2022, 04:55 AM
RE: Armbian on Quartz64 - by mulimoen - 02-14-2022, 12:11 PM
RE: Armbian on Quartz64 - by balbes150 - 03-13-2022, 11:04 AM
RE: Armbian on Quartz64 - by tllim - 03-14-2022, 06:07 PM
RE: Armbian on Quartz64 - by balbes150 - 03-17-2022, 06:29 AM
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 148 61,214 05-02-2024, 09:09 AM
Last Post: balbes150
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 0 239 03-27-2024, 12:53 PM
  DietPi OS for Quartz64 MichaIng 45 11,435 12-12-2023, 02:26 AM
Last Post: sickos
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 41,821 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 1,193 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 883 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 1,392 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 5,077 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 1,269 07-21-2022, 01:08 PM
Last Post: Randomuser
