Some "tricks and tips" for Manjaro Plasma Mobile
I have found in the recent weeks that Plasma Mobile has become quite useful, and works quite well.
If WiFi is disabled, MMS messaging works well, though I do not like 'group chats ' and have not tried one.
The half black screen issue still occasionally crops up, though rotating the phone fixes it.  Phone screen rotation seems to be controlled in 2 separate places the top tray button 'Auto-rotate' as well as 'Settings->Display Configuration->Orientation'  I have found that using 'Automatic' with 'Only when in tablet mode' *unchecked* works correctly.
The on screen keyboard works really well, though the emoji portion shows small emoji, making some unclear.
The three biggest issues I have found are:
1) not being able to hook up to my computer via USB cable to use sftp/ssh connections, and it must be done using a wireless connection.
   there is an open bug about this, and indicators on how to fix this, with those fixes purportedly in the kernel + the manjaro tweaks package, though I have yet to dig deep enough to fix it.
2) playing music and locking the screen make the phone become unusable.  the preinstalled 'wave' program nearly crashes it, while audacious continues to play fine, though the phone becomes inaccessible, being a black screen no matter what button I push.
3) The phone rings through the ear piece, though this can be mitigated by switching the audio to come from the internal speaker, however this makes all phone calls on speaker, with no way to adjust it, unless you switch the 'Settings->Audio->Playback Devices->Port'  back to 'Internal Earpiece' once the call has started.
Any tips for how to fix the music/lock screen issue would make this much more usable.
Another issue is using retroarch with the overlay display gamepad.  It does not register input.
RE: Some "tricks and tips" for Manjaro Plasma Mobile - by israel - 03-10-2022, 10:38 AM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,627 10-02-2023, 05:07 AM
Last Post: Uturn
  Manjaro: Settings doesnt open nbh 0 599 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,525 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,608 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 816 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,813 03-02-2023, 07:25 PM
  gnome-mobile dev Uturn 1 1,124 02-22-2023, 03:37 AM
Last Post: acrux
  Can't install Manjaro thorensjubilee 1 1,038 02-09-2023, 08:17 AM
  Manjaro plasma-mobile Beta 13 Uturn 13 4,927 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,590 11-22-2022, 05:00 PM
Last Post: Chief
