Some "tricks and tips" for Manjaro Plasma Mobile
1. Keep in mind that PinePhone components were originally not intended to use in mobile phones, so set your expectations accordingly.
2. PinePhone software has not reached even a "release candidate" level, so set your expectations accordingly.
3. The following reflects my experience. Your mileage may vary, so do not blame me if something goes wrong.
4. The PinePhone preloaded Plasma Mobile (PlaMo) operating system may be outdated, so it is good idea to do a fresh start. All information how to install is listed here.
5. Manjaro provides different PlaMo Development Pinephone Images to install. There are Development Pinephone unstable images which are based on KDE unstable branch and Plasma-Mobile "daily build" unstable images which are based on KDE stable branch. However - there could be from time to time several problems with these images (eg non-booting or something broken etc), so it is good idea to test them installing to the sd card.
6. At certain intervals Manjaro team is releasing Beta releases. If you want something that is close to "stable" to install to the eMMC, then I'd recommend to use these. The latest beta is Release Beta 14 and is located here. The announcement is here. Be prepared that for beta the updates are arriving less frequently as it has it's own updates channel.
7. While PlaMo software manager Discover has great potential, it seems that it is not ready yet. It does not list all software and from time to time may fail in some extent in software update. Instead Discover I'd recommend Manjaro commandline tool pacman. So for updates run in Terminal:
sudo pacman -Syu
8. The same goes for searching, installing and removing programs. Study Manjaro Pacman overview here. For example - to remove closed source (server part) communication program Telegram: sudo pacman -Rsun telegram-desktop
9. If you rely on xmpp&jabber communication, then your options are kaidan and dino(-mobile). Kaidan is native PlaMo software, but not ready yet. There is no multuser chat and message archives are not syncronised correctly. Install it using pacman, as Discover lists an older flatpak version. Dino-mobile was the best choice, unfortunately it is not installable any more. You can try the desktop version but it is not optimised to phone screen.
10. If you need a PlaMo e-mail client, then you are out-of-luck. There was a project Pelikan, but it seems to be stalled. Of course - you can install Geary, but it pulls in much of Gnome packages, so it is more sense to run it under Phosh.
EDIT: This is last update here (June 1st 2023) as my PinePhone found a new user/tester and probably goes to Maemo Leste way...
Some "tricks and tips" for Manjaro Plasma Mobile - by acrux - 11-10-2021, 02:31 AM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,642 10-02-2023, 05:07 AM
Last Post: Uturn
  Manjaro: Settings doesnt open nbh 0 602 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,543 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,614 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 823 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,836 03-02-2023, 07:25 PM
  gnome-mobile dev Uturn 1 1,127 02-22-2023, 03:37 AM
Last Post: acrux
  Can't install Manjaro thorensjubilee 1 1,039 02-09-2023, 08:17 AM
  Manjaro plasma-mobile Beta 13 Uturn 13 4,949 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,597 11-22-2022, 05:00 PM
Last Post: Chief
