Ribbon Cable Extenders ?
(08-03-2016, 12:45 PM)JulianM Wrote:
(08-02-2016, 10:56 PM)jodybrown99 Wrote: yeah, that's 20 of them. but i couldnt find less than that for any better price. getting just 1 was the same price as 20.
and i used the extending adapter from the other purchase to connect it
How have you connected your touchpanel cable with the 30-pin-adapter?
Just on the same ports on each side?
Best regards
Julian
(08-03-2016, 01:44 PM)JulianM Wrote: Alright, sound easy.
Thanks marcushh777.
This cable should also match the conditions for touchpanel, right?
- http://www.ebay.de/itm/FFC-A-6Pin-0-5Pit...1866201167
It's more expensive as the given product here in the topic, but I can't order the other cable for addresses in Germany or Austria :/
Best regards
Julian
yes, exactly.
[Image: e93IO1g.jpg]
http://imgur.com/e93IO1g
and yes that cable you linked looks fine to me. i took a gamble but it works.
look for a multi-pack. you might actually find one cheaper. as mentioned, i could only find singles for more than it cost me for a 20-pack.
Ribbon Cable Extenders ? - by Severian - 06-26-2016, 06:08 AM
RE: Ribbon Cable Extenders ? - by tllim - 06-26-2016, 07:07 PM
RE: Ribbon Cable Extenders ? - by Bluphire - 07-24-2016, 10:38 AM
RE: Ribbon Cable Extenders ? - by tllim - 07-25-2016, 12:59 PM
RE: Ribbon Cable Extenders ? - by InspectorDigit - 07-03-2016, 12:20 AM
RE: Ribbon Cable Extenders ? - by dkryder - 07-24-2016, 11:42 AM
RE: Ribbon Cable Extenders ? - by InspectorDigit - 07-24-2016, 02:02 PM
RE: Ribbon Cable Extenders ? - by dkryder - 07-24-2016, 04:42 PM
RE: Ribbon Cable Extenders ? - by Bluphire - 07-24-2016, 09:58 PM
RE: Ribbon Cable Extenders ? - by Bluphire - 08-01-2016, 04:14 PM
RE: Ribbon Cable Extenders ? - by jodybrown99 - 08-02-2016, 10:56 PM
RE: Ribbon Cable Extenders ? - by JulianM - 08-03-2016, 12:45 PM
RE: Ribbon Cable Extenders ? - by JulianM - 08-03-2016, 01:44 PM
RE: Ribbon Cable Extenders ? - by jodybrown99 - 08-04-2016, 02:11 PM
  Cable for LCD sbentjies 21 30,385 07-03-2016, 04:19 AM
Last Post: robpaz
