scp.bin not found, can't complete apt upgrade
So I've been dinking around ignorantly and discovered something...
whatever script apt upgrade calls runs a script which does
md5sum /usr/lib/crust/scp.bin
which errors our.
/usr/lib/crust on my machine is a symbolic link to the *file* /usr/lib/crust-firmware/pinephone
I'm guessing it should be a symbolic link to /usr/lib/crust-firmware and/or /usr/lib/crust/scp.bin should be a symbolic link to /usr/lib/crust-firmware/pinephone.
I'm not experienced or knowledgeable enough to fix this, however Sad
I seem to have fixed it.
I cded to /usr/lib/crust-firmware
then "cp pinephone scp.bin"
then I unlinked the symlink from /usr/lib/crust
"unlink /usr/lib/crust"
then I linked the directory to the directory
"ln -s /usr/lib/crust-firmware /usr/lib/crust"
Then I did a sudo apt upgrade and the upgrade appears to be proceeding
RE: scp.bin not found, can't complete apt upgrade - by Hiraghm - 10-16-2021, 07:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 666 09-01-2023, 11:29 AM
Last Post: Mahgue
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 1,002 03-06-2023, 12:06 PM
Last Post: freelectro
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,292 03-01-2023, 04:45 PM
Last Post: anonymous
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 1,036 01-04-2023, 06:46 PM
Last Post: 3x5co
Exclamation No modems were found: No mobile data, no 2G anonymous 2 1,443 12-26-2022, 06:46 PM
  Receive MMS fails after Nov 27 upgrade treebeard 17 6,267 12-12-2022, 05:09 AM
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,234 09-30-2022, 08:53 PM
Last Post: treebeard
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 5,005 09-23-2022, 05:15 AM
  New Tow-boot release, how to upgrade? user641 3 1,969 08-23-2022, 08:45 AM
Last Post: user641
  GPS/location services don't work with Maps after Bookworm upgrade Anna 16 10,431 06-13-2022, 02:37 PM
Last Post: wibble
