scp.bin not found, can't complete apt upgrade
I'm running Bookworm on my community edition Pinephone.
For the past couple weeks, every time I've tried a "sudo apt upgrade", it errors out with the error that it can't find /etc/lib/scp.bin.
I've tried running the Software app, it can't download the updates, complains of missing dependencies (but doesn't say what they are),
and now when I try to run apt update, it 404 errors on trixie-security and trixie-updates, then says there's no release file for trixie-security and trixie-updates, therefore they can't be updated securely and are disabled.
I tried sudo apt-get clean followed by sudo apt-get check followed by sudo apt-get -f install
after that it listed some packages that could be removed and then said 0 updated, 0 newly installed, 18 to remove, 380 to upgrade.
so I tried autoremove and got the original error:
md5sum: /usr/lib/crust/scp.bin: no such file or directory
And then I get two errors when the script tries to run scp.bin
Does anyone have any clue what is happening and what I need to do to fix it? Do I have to do a complete re-install? Sad
scp.bin not found, can't complete apt upgrade - by Hiraghm - 10-16-2021, 10:22 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 666 09-01-2023, 11:29 AM
Last Post: Mahgue
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 1,002 03-06-2023, 12:06 PM
Last Post: freelectro
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,292 03-01-2023, 04:45 PM
Last Post: anonymous
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 1,036 01-04-2023, 06:46 PM
Last Post: 3x5co
Exclamation No modems were found: No mobile data, no 2G anonymous 2 1,443 12-26-2022, 06:46 PM
  Receive MMS fails after Nov 27 upgrade treebeard 17 6,267 12-12-2022, 05:09 AM
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,236 09-30-2022, 08:53 PM
Last Post: treebeard
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 5,007 09-23-2022, 05:15 AM
  New Tow-boot release, how to upgrade? user641 3 1,972 08-23-2022, 08:45 AM
Last Post: user641
  GPS/location services don't work with Maps after Bookworm upgrade Anna 16 10,438 06-13-2022, 02:37 PM
Last Post: wibble
