BT WONT CONNECT
(10-05-2021, 03:37 AM)wibble Wrote: You've given zero detail about what you've actually tried, so it's difficult to help you. Does your hardware support BLE, which is required, or just classic Bluetooth which won't work? Which software have you tried and what exactly did you try to do with it?
Wibble,
Thanks for the reply, to be honest I hadnt realized the difference of the BT5 and BTE but I'll give it a shot.
Bottom line, this far I have tried Linux Mint 20.1 w/ the KDE BT util, but I'll look further on the BR vs BTE
Microsoft Surface and Lennovo 2in1 with Win10, built in util
Then my android tablet and phone, using several apps including amzfit and MyAir
However, if you have a KNOWN good app/prog/util that works in one of the 3 listed environments Im more than happy to try it.
It just amazed me that I can pick up my wifes fitbvit and sons galaxy watch across the hopuse and cant see the pine time on the desk
rthx
j
actually change that, not Amzfit, but Gadgetbridge
BT WONT CONNECT - by mindwave - 10-04-2021, 08:01 PM
RE: BT WONT CONNECT - by wibble - 10-05-2021, 03:37 AM
RE: BT WONT CONNECT - by mindwave - 10-07-2021, 02:28 PM
RE: BT WONT CONNECT - by mindwave - 10-08-2021, 05:24 PM
RE: BT WONT CONNECT - by wibble - 10-08-2021, 06:12 AM
RE: BT WONT CONNECT - by Mpoint - 10-09-2021, 11:57 AM
RE: BT WONT CONNECT - by wibble - 10-10-2021, 04:50 AM
RE: BT WONT CONNECT - by sandworm - 11-18-2021, 06:52 AM
RE: BT WONT CONNECT - by danielt - 11-19-2021, 03:18 AM
  Connect to Google Fit on Android? Ccssid 0 428 12-24-2023, 09:06 AM
Last Post: Ccssid
  Watchmate doesn't connect to PT anymore jojuma 1 1,437 02-07-2023, 02:43 AM
Last Post: azymohliad
  can anyone suggest their working Linux bluetooth USB dongles to connect to Pinetime? jahway603 4 2,746 07-27-2022, 07:38 PM
Last Post: jahway603
  Flashing with RF Connect ronaldheld 12 7,483 04-28-2022, 04:27 AM
Last Post: ITCactus
  Gadgetbridge vs RF Connect ronaldheld 2 2,487 03-30-2022, 06:14 AM
Last Post: danimations
  PineTime re-connect to PInephone kmsgli 8 5,458 01-01-2022, 08:05 PM
Last Post: kmsgli
  After 0.7 -> 1.0 update cannot connect bluetooth piner67 2 3,126 06-21-2021, 01:39 PM
Last Post: piner67
