display resolution setting
(06-23-2016, 09:56 AM)MarkHaysHarris777 Wrote: Unfortunately that monitor does not support 1080p60 (and that's what you need).  It only does 1280x1024 @75... not good.
You need this monitor; I have a couple of these... they work great !  (and they're relatively inexpensive)
Thanks for your reply.
Is that an issue with Ubuntu only ?
I also have an android build on a different SD Card and display resolution on that works perfect on Pine.
I have 2 monitors, both 17" - both only do 1280x1024
Dont particularly want to spend a fair amount on a new monitor, this was supposed to be a cheap build by using Pine, its adding up by the time I bought a case to house Pine board, a mouse, keyboard, SD Cards and picked up the 17" monitor on the cheap
display resolution setting - by frustrated1 - 06-23-2016, 09:37 AM
RE: display resolution setting - by jl_678 - 06-23-2016, 09:43 AM
RE: display resolution setting - by frustrated1 - 06-23-2016, 09:50 AM
RE: display resolution setting - by frustrated1 - 06-23-2016, 10:10 AM
RE: display resolution setting - by dhardingham - 06-23-2016, 10:42 AM
RE: display resolution setting - by cristiano - 07-04-2016, 02:55 AM
  Clock Setting 12 hrs coolnine98 2 5,865 06-30-2022, 09:38 AM
Last Post: sblaydes
  How to change DSI setting value from DTS r.tanaka 8 12,260 08-28-2018, 03:52 AM
Last Post: r.tanaka
  Trouble setting up psensor (or any other) DukeJustice 9 11,050 08-16-2016, 06:47 AM
Last Post: DukeJustice
  Ubuntu and LCD Display dcmorley 3 5,108 07-09-2016, 02:26 PM
Last Post: yodermk
