Case hardware request/idea
(09-12-2021, 03:59 AM)wibble Wrote: The six pins on the back can be used for an extra battery - and will be in the keyboard case which is hoped to be in the store later this month. The 2g/3g/4g antenna is already using a coax connector (UFL I think) so changing to a better antenna should be easy. The GPS antenna is trickier but I think there have been a couple of attempts, one soldering a coax cable to the board in place of the sprung contacts, and another enlarging the existing printed antenna with some aluminium tape.
Im assuming that keyboard is detected as a usb rather than serial device is this the case? If so any usb capable gps or lte antenna could be incorperated and utilize the break out pins then.
Case hardware request/idea - by HobanWashburn - 09-11-2021, 08:07 AM
RE: Case hardware request/idea - by wibble - 09-12-2021, 03:59 AM
RE: Case hardware request/idea - by HobanWashburn - 09-12-2021, 07:06 AM
RE: Case hardware request/idea - by wibble - 09-14-2021, 08:36 AM
RE: Case hardware request/idea - by 8bit - 09-12-2021, 08:08 AM
RE: Case hardware request/idea - by biketool - 09-15-2021, 04:02 AM
  Microphone on Hardware Model 1.2 is Unusably Noisy In Some Circomstances ASmartSuitedSimpleton 4 4,007 03-23-2024, 10:55 AM
Last Post: Ferriah
  Is the hardware still being developed and refined? orbital 10 5,235 09-01-2022, 08:05 PM
Last Post: orbital
  How to check hardware revision? jojuma 1 1,634 07-16-2022, 12:28 AM
Last Post: bokomaru
  Modem Hardware bad? Not ready for 5g?? linux76 8 4,877 05-31-2022, 06:41 PM
Last Post: SwordfishII
  adding some keys to pp keyboard case, pageup, pagedown, f11, f12, maybe others zetabeta 1 1,334 04-30-2022, 08:18 PM
Last Post: TRS-80
  Any experiences with hardware mod to improve eMMC speeds? kqlnut 9 6,101 04-19-2022, 02:36 PM
Last Post: kk22
  Hardware switch for mic is not working properly submariner 10 7,830 01-25-2022, 07:01 AM
Last Post: wibble
  Request for Files regarding new cases [REDACTED] 0 992 01-02-2022, 01:42 AM
Last Post: [REDACTED]
Bug [Support Request] Modem is Failing to Be Accessible FriendlyGecko 3 2,925 11-30-2021, 01:22 PM
Last Post: FriendlyGecko
  PinePhone Hardware Critique KABA 2 2,942 08-13-2021, 06:47 PM
