Mobian September 01, 2021
Just flashed a September 01 Nightly to an sd card,  running on a Pine Manjaro Convergent phone.
It did the normal disk 'resizing',     But there was no pop-up to help put the basic information into the phone.
  Now there is not a flashlight app on the desktop,  or in the onboard Software Store. ?
I did the "Updates" via   settings > about > update,  that went normally  using the wifi...
I attempted to use the cell/data after putting in my APN info, and turned on mobile data,  both Epiphany and Firefox would not load.
Then turned wifi back on,  Epiphany loaded...  turned wifi off again,  mobile data back on,    this time Epiphany loaded via cell/data.
Calls work both directions,  while the other person can hear me clearly, and they sound clear to me,  but I sound distorted to myself on the ear piece.
The text works, both in and out.  ...
AND  in the Power App,  with wifi off,  data off  just the modem on,
    While running on the battery,     it is showing between 2.0 and 2.2 watts of discharge. !
That is getting the power consumption down,  a bit lower with each release.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Mobian September 01, 2021 - by bcnaz - 09-01-2021, 04:15 AM
RE: Mobian September 01, 2021 - by ragreenburg - 09-01-2021, 09:40 AM
RE: Mobian September 01, 2021 - by bcnaz - 09-01-2021, 11:45 AM
  atinout binaries for mobian/debian? NeutralGrey 2 84 Yesterday, 02:42 PM
Last Post: Gumur
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,755 05-09-2024, 03:08 AM
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,133 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 168 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,123 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,902 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 664 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,149 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,962 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 661 07-05-2023, 03:57 AM
Last Post: paulcarton
