Handwriting recognition?
I'm still looking for good FLOSS HWR, possibly https://github.com/githubharald/SimpleHTR , and so far tinkered with OCR e.g Tesseract. It's terrible https://twitter.com/utopiah/status/1321152581717078017 but feasible even on less powerful hardware.
On "boxier" boxes I had similar discussion on Inkscape and there is some work e.g https://inkscape.org/~qpad/%E2%98%85shape-recognition which ironically enough does not demand anything fancy, namely that if you have a certain type of curve, basically something close enough according to your threshold, to a line then you remove the number of points. If you do it properly it will flatten it. You can also go the ML way with shape recognition from a catalogue of shape though or mix the two.
Handwriting recognition? - by KJ6OHG - 08-23-2021, 12:28 AM
RE: Handwriting recognition? - by barray - 08-23-2021, 01:21 AM
RE: Handwriting recognition? - by biketool - 08-23-2021, 03:17 AM
RE: Handwriting recognition? - by jasonriedy - 08-25-2021, 09:51 AM
RE: Handwriting recognition? - by poVoq - 10-17-2021, 06:00 AM
RE: Handwriting recognition? - by jasonriedy - 10-19-2021, 06:28 PM
RE: Handwriting recognition? - by utopiah - 05-31-2022, 12:30 PM
  Handwriting recognition app serko43 0 1,035 05-01-2023, 04:07 PM
Last Post: serko43
Question How to write handwriting note app that not delay in android app for PineNote? wannaphong 0 1,809 10-30-2022, 07:29 AM
Last Post: wannaphong
