Total Noob. Need help booting from SD
(08-22-2021, 09:58 PM)KC9UDX Wrote: Well, if you have a U-Boot on your eMMC that doesn't like to boot SD cards (yes this happens) then it is time to disable the eMMC.  You may as well do that anyway just to make things easier.  But study the images in the wiki carefully (hopefully there are still good images there), to make sure you are switching the right switch.  You could even remove the eMMC if you want.  It just pulls straight up.  It looks scary, but it isn't.
I would recommend against pulling eMMC off the board unless there is no other way, because the connector used for eMMC modules is not rated for many mating cycles and I would expect it to wear out fast.
This message was created with 100% recycled electrons
RE: Total Noob. Need help booting from SD - by moonwalkers - 08-23-2021, 01:30 PM
  Followed the blog post to install Fedora: PBP not booting anymore koenigs 6 1,895 06-01-2023, 10:58 AM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,503 04-23-2023, 06:58 AM
Last Post: acruhl
Exclamation PineBook Pro shuts down immediately after booting zogkarndon 5 2,015 01-10-2023, 10:16 AM
Last Post: Perl6_user
Wink Booting Windows on bare-metal rk3399 SBC (no linux involved) strongtz 9 10,546 05-26-2022, 11:36 PM
Last Post: strongtz
  PInebook not booting with eMMC enabled aragaer 4 4,265 10-25-2021, 09:11 PM
  Manjaro i3 Edition not booting mtndew 0 1,591 08-23-2021, 06:21 PM
Last Post: mtndew
Video Problem Booting from SD card ezryder324r 0 1,478 05-19-2021, 02:42 PM
Last Post: ezryder324r
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 1,767 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  Booting to sdcard stopped working after emmc flash techiedog 3 3,947 12-31-2020, 06:30 PM
Last Post: Anarethos
  Booting - User device selection in U-Boot? Arwen 10 11,972 11-21-2020, 01:22 PM
Last Post: Arwen
