Which PineNote would you prefer?
without modem as announced
84.00%
21
internal 3g/5g modem, higher price
16.00%
4
25 vote(s)
What sort of peripherals would you like to see for the PineNote? Internal 3g/5g modem
I've bought 3 e-readers. The last two are ONYX M92/9" and ONYX Max2/13" from years. At this moment, I'm working with the Max2 for a professional usage.
I would connect a keyboard and maybe a mouse directly. Or to use a very small HUB that doesn't require an external power supply like for the Max2. More than USB/USB-C port could be a good idea.
A port for an external memory like SD-Card is a missing on the ONYX Max2. You can read the dedicated thread to ONYX here : https://www.mobileread.com/forums/forumd....php?f=220 A good source of ideas.
The WiFi or Bluetooth are not always the best solutions when you have some strict security rules. A SD-Card that could be checked is a better choice, you know exactly what there is on it. After you can erase the SD-Card to avoid that some bad things from the e-reader goes to in the IT. In some cases : WiFi and Bluetooth are forbidden, so you can't load the e-reader if you haven't a physical access.
The Max2 has a HDMI input port. I can use as first or second monitor. The problem is the management off this screen. Under Linux it is easier than Windows.
RE: What sort of peripherals would you like to see for the PineNote? Internal 3g/5g modem - by Gribouille - 08-17-2021, 08:58 AM
Sad PineNote is Out of stock. DimitriBolt 15 1,410 01-13-2023, 12:53 AM
Last Post: BronzeBeard
  Who is the target audience of the PineNote pinesucker 3 1,452 09-18-2022, 11:17 PM
Last Post: zer0sig
  Terminal program (RS232/USB) on PineNote? roman 0 433 08-19-2022, 02:41 AM
Last Post: roman
  e-paper pinephone? smaller screen pinenote? ideograph 6 5,416 09-20-2021, 03:05 PM
Last Post: darnel
  Pine64 Announces The PineNote - A New Linux Powered E-Ink Tablet! ImmyChan 0 1,739 08-16-2021, 01:58 PM
Last Post: ImmyChan
