Manjaro KDE dolphin not showing usb device
Hi, I can see usb device in the manage disks utility, but I can't access the device through dolphin. I can manually mount & access through console.
Has anyone had this problem? Any suggestions appreciated. Thanks, straightwalker
SOLVED
more or less. The Disks utility recognizes a hot plugged usb and allows mounting and/or unmounting and offers options that can be edited.
If the drive is in when the PBP is booted, the Disk utility will mount it in /ROOT/mnt/usbname. If the drive is put in after the boot, the Disk utility mounts it in /ROOT/media/usrname/usbname (or maybe it has a "/run" in that path, I don't remember). In any case, Disks lists the path to the mounted usb drive, and you can access the contents using Dolphin (by beginning the path with ROOT).
There is probably a way to automate this, or make it less manual, but I couldn't figure it out. At least, you can access any drive you put in. If you are using the same usb drive each time (and you get the settings right), the process is automatic. It seems that you have to set up options for each new drive that you use.
I'm sure others can explain better ways. But it does work, even though an added device never appears on the Dolphin sidebar.
Manjaro KDE dolphin not showing usb device - by straightwalker - 07-30-2021, 09:51 AM
  Manjaro versions bad and good gilwood 0 249 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,225 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 696 12-13-2023, 08:17 PM
Last Post: trillobite
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 318,983 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 1,474 05-08-2023, 11:17 AM
  PBP blank screen after updating Manjaro Franko 6 2,022 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 571 04-01-2023, 03:21 AM
Last Post: hacknix
  Partial boot after installing Manjaro on emmc regivanx 11 3,193 02-06-2023, 09:11 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 4,789 01-22-2023, 10:05 PM
Last Post: rfm83
  No boot after Manjaro flash PBcurry 14 5,482 10-03-2022, 08:33 PM
