on off power button stopped working
@tllim thanks a lot for the flex, I have received it.
I removed the old one carefully (it is stuck on a metal strip) using a screwdriver and razor blade. The new one can be stuck in place (remove plastic from the rear and it's ready to go).
I connected the new flexi to the motherboard and the on / off button works, as do the volume up/down buttons!
I'm not sure how to avoid the issue again if I connect / disconnect it in the future.
on off power button stopped working - by dcinoz - 07-24-2021, 05:07 AM
RE: on off power button stopped working - by dcinoz - 09-01-2021, 03:26 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 577 02-17-2024, 04:15 PM
Last Post: vortex
  Pinephone - broken power button rorus 10 9,337 05-18-2023, 09:11 AM
Last Post: kbm
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,555 03-20-2023, 12:54 AM
Last Post: bcoyle
  modem not working michelinux 0 940 02-16-2023, 04:56 AM
Last Post: michelinux
  Power supply vs battery albafrati 11 4,750 06-22-2022, 06:04 PM
Last Post: albafrati
  Hardware switch for mic is not working properly submariner 10 7,756 01-25-2022, 07:01 AM
Last Post: wibble
  New vibration motor not working Zebulon Walton 5 5,608 11-13-2021, 03:00 AM
Last Post: kqlnut
  Power consumption during the call some_pinephone_user 0 1,156 10-29-2021, 06:03 AM
Last Post: some_pinephone_user
  Won't boot until connected to power after sudden power loss brb78 1 1,746 08-30-2021, 12:41 AM
Last Post: bcnaz
  Regarding USB Power and Modem Initialization vidual 2 2,754 08-26-2021, 11:48 PM
Last Post: vidual
