jumpdrive software might be faulty (or my pinephone hardware)
(07-19-2021, 06:55 AM)zetabeta Wrote: jumpdrive software might be faulty (or my pinephone hardware)
this is quite preliminary view and when i get more information, i clarify what's going on. still it's headzup issue for some. i have pinephone hardware 1.2a.
i noticed that using jumdrive software, both 0.7 and 0.8, computer only saw 6GB intenal storage instead of 32GB. using telnet, then size was correct. this meant that flashing was not succesful.
https://github.com/dreemurrs-embedded/Ju...e/releases
i ended up installing o.s. to the memory card and after that i installed to the internal memory.
serious disclaimer, my pinephone could be faulty by hardware because i have some issues with gps as well.
probably false alarm
seems to be that i have problem with my computer, in this case debian. for some reason 32GiB usb memories function as 6.79GiB in size. happened also with other usb memory. actually usb adapter for sd card.
RE: jumpdrive software might be faulty (or my pinephone hardware) - by zetabeta - 07-19-2021, 03:38 PM
  PinePhone - boot from microSD laserpyramid 7 627 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 367 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 246 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,630 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,855 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 624 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,411 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 511 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,734 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,004 12-04-2023, 02:14 AM
Last Post: Peter Gamma
