DOA Board? "UNSUPPORTED VIDEO"
i have the same problem except I received two pine 64, (pledged the $89.00 kick starter kit and ordered extra board) one boots up on android lcd using 16 gig sd card with the 8 gig image swap the card and lcd panel it doesn't boot switch back to the first board an it boots perfect. I also received the 64 sd card in the kit which does not boot and when I read the card it says 28 gig available and no file available. Since one works great and I can not get the other to boot then the conclusion would be DOA, both boards are the same A64-DB-V1.1 2G
DOA Board? "UNSUPPORTED VIDEO" - by phloog - 06-19-2016, 01:26 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by xalius - 06-19-2016, 02:17 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by phloog - 06-19-2016, 03:07 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by xalius - 06-19-2016, 04:13 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by Ghost - 06-19-2016, 04:13 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by phloog - 06-19-2016, 04:39 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by phloog - 06-20-2016, 08:29 AM
RE: DOA Board? "UNSUPPORTED VIDEO" - by ptbrownie - 06-24-2016, 01:21 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by xalius - 06-24-2016, 02:09 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by ssvb - 06-24-2016, 02:38 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by ptbrownie - 06-24-2016, 02:39 PM
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 1,611 10-06-2022, 08:46 PM
Last Post: ihab
  Video conferencing aproject oxoocoffee 1 3,095 03-31-2020, 09:24 PM
Last Post: Dendrocalamus64
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 15,733 05-15-2019, 02:55 PM
Last Post: Thatoo
  My first Single Board! jjh221 4 6,876 04-09-2018, 06:52 PM
Last Post: jjh221
  sopine cluster board install Smurfbot 1 4,452 03-31-2018, 04:09 AM
Last Post: pfeerick
  What is the format that one should use for imaging SD cards on APINE64+2GB Board? Doryan 1 3,573 03-05-2018, 08:11 PM
  Which board to use? Dayve 0 2,315 02-18-2018, 06:31 AM
Last Post: Dayve
  Kodi on Rock64 board cenguix 2 8,928 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
  What are these pins on PIN board? dims 1 3,299 01-15-2018, 11:21 AM
Last Post: Luke
  red led + cat5 lights but noshow on DHCP list, no video mckenna.tim 1 3,869 01-24-2017, 12:03 PM
Last Post: Luke
