printing -- Manjaro ARM KDE plasma
(06-28-2021, 12:38 PM)straightwalker Wrote:
(06-28-2021, 11:30 AM)jiyong Wrote: Did you try searching for CUPS packages with Pamac?
Launcher > System > Add/Remove Software
Thank you for the suggestion. Pamac lists cups package successfully installed, nothing missing.
Several forum members have pointed me toward Airprint as an all purpose generic driver. I can't find where to employ it. CUPS wants a ppd file. I have downloaded two ppd files from openprinting.org (thanks to a suggestion) that are supposed to work with Brother HL-L2340DW, but the print job hangs up with "filter failed" message.
The Bonjour (modern) method of connecting requires a printer URI which I can get with the lprint command. But, that command has a dsnsd parameter which I don't seem to have.
My printer has wifi capability, but I have been trying to connect through USB. It should work either way. The printer connection instructions in Debian and Arch forums are clear and simple. Is puzzle.
I have a similar printer.  It seems to work better via wireless with just the "Generic" printer type, and either ipp or lp as the connection type.  Then it's just the ip address for the URI (at least for me).  Printing works fine on mine once you get it set up.
RE: printing -- Manjaro ARM KDE plasma - by wdt - 06-28-2021, 10:17 AM
RE: printing -- Manjaro ARM KDE plasma - by carlosqueso - 06-28-2021, 06:23 PM
RE: printing -- Manjaro ARM KDE plasma - by yoshi - 07-04-2021, 05:33 PM
RE: printing -- Manjaro ARM KDE plasma - by wdt - 06-28-2021, 03:55 PM
  Manjaro versions bad and good gilwood 0 256 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,247 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 708 12-13-2023, 08:17 PM
Last Post: trillobite
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 319,832 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 1,480 05-08-2023, 11:17 AM
  PBP blank screen after updating Manjaro Franko 6 2,026 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 574 04-01-2023, 03:21 AM
Last Post: hacknix
  Partial boot after installing Manjaro on emmc regivanx 11 3,201 02-06-2023, 09:11 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 4,797 01-22-2023, 10:05 PM
Last Post: rfm83
  No boot after Manjaro flash PBcurry 14 5,489 10-03-2022, 08:33 PM
