Device unable to boot
I've just looked through the posts you've recommanded.
I've flashed an os on the SD card I know has HDMI output (Armbian Buster) and did some more testing.
I've tried the power + reset solution by pressing both at the same time for 2 sec and doing a 2sec power followed by 2sec reset then pressing the power button once more to power on the device but without any result all no white led, nor any HDMI output.
When it comes to the power and reset pin holes next to the audio jack, I've tried jumping the power and ground as in this post (https://forum.pine64.org/showthread.php?pid=77022), it just powered off the device. From what I can understand those pins are the same as the buttons, unless I've misunderstood what they are used for.
For the `(or on power off touch all the gpio pins  before)` part, I'm not sure I get what you mean by that.
On the serial interface side of things. I didn't expect there could be fake FTDI IC, but after some research, I found my FTDI programmer might be a fake.
So far it worked just fine with lower speed devices like some other SBC and dev board, but maybe not with this board.
I've ordered a new serial interface with a genuine FTDI chip and will try to see if I can get any output out of the board once I'll receive it.
Device unable to boot - by Lunix33 - 06-15-2021, 09:51 PM
RE: Device unable to boot - by LMM - 06-20-2021, 03:18 AM
RE: Device unable to boot - by Lunix33 - 06-22-2021, 07:51 AM
RE: Device unable to boot - by LMM - 06-22-2021, 11:58 AM
RE: Device unable to boot - by LMM - 06-22-2021, 01:09 PM
RE: Device unable to boot - by Lunix33 - 06-22-2021, 08:17 PM
RE: Device unable to boot - by Lunix33 - 07-04-2021, 06:00 PM
RE: Device unable to boot - by t4_4t - 07-05-2021, 08:25 PM
RE: Device unable to boot - by Lunix33 - 09-22-2021, 10:31 AM
RE: Device unable to boot - by LMM - 09-23-2021, 01:38 AM
  enble boot after power loss/restore dkebler 18 9,495 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 119,871 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 676 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,277 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,339 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,556 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,240 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,155 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,813 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,166 06-09-2022, 10:56 AM
Last Post: pspgarret
