inner earpiece speaker replacement
(07-24-2021, 01:48 AM)kqlnut Wrote: I'm don't know much about Pipewire (maybe try with pactl?), but have you checked if it might be a physical problem? Maybe the metal prongs don't make good contact or the speaker grill (if there is one) is dirty.
I tried with the second replacement earpiece speaker (same model) but the unfortunately result is the same. The motherboard contacts don't look evenly coloured/smooth but that is presumably where the original speaker made the contacts. Speaker contacts are fine otherwise there would be no sound. No dirt.
Upon reassembly the on/off button no longer does anything - I'll open another thread for that. Disappointed.
I set the volume to 150% using
pactl set-sink-volume 0 150%
but that didn't change anything.
inner earpiece speaker replacement - by dcinoz - 06-10-2021, 01:34 AM
RE: inner earpiece speaker replacement - by dcinoz - 07-24-2021, 04:37 AM
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,446 10-12-2023, 01:03 PM
Last Post: robthebold
Bug DESIGN ISSUE? Speaker + vibration motor broke for the 2nd time e1337 11 4,527 01-26-2023, 10:11 PM
Last Post: AnAbolitionist
  Screen Replacement Instructions erikkugel 4 3,224 09-07-2022, 11:04 PM
Last Post: RTP
  Microphone replacement SocialNetworkingWasAMistake 1 1,574 08-05-2022, 03:16 PM
Last Post: calinb
  Lost internal earpiece Veraendert 3 2,423 02-14-2022, 07:51 AM
Last Post: Veraendert
  PWM whine near earpiece in low signal phone call and loud sound sent to the other end vortex 29 26,738 01-14-2022, 11:00 AM
Last Post: eugenr
  Screen replacement Csanderson0313 4 3,305 01-10-2022, 09:26 PM
Last Post: Csanderson0313
  Replacement Loud Speaker kmsgli 18 14,780 11-01-2021, 12:25 PM
Last Post: mickclark430
  LCD panel replacement instructions mob 2 2,269 09-13-2021, 05:11 PM
Last Post: mob
  Battery replacement alternative sax1960 7 6,408 08-29-2021, 07:03 AM
Last Post: bcnaz
