How to Save Read Only Files, Questions on Location
(06-10-2021, 12:31 AM)evilbunny Wrote:
(06-09-2021, 08:53 PM)lovepine88 Wrote:
(06-07-2021, 06:24 AM)evilbunny Wrote:
(06-06-2021, 02:08 PM)lovepine88 Wrote: I am trying to edit the geoclue.conf file, but it says it's read only. I don't know how to change that.  Huh  I am using Thunar. I got into su mode in king's cross, but not sure that helped.
Also, I have the modem disabled. Will pinephone still be able to know my location via gsm chips built into the hardware even if I edit geoclue?
In other words, if the modem is off and there's no SIM chip, am I still connected to a satalite anyway?
Use sudo before the app name, this will give you root level access.
Hello EvilBunny. In King's Cross, I typed sudo thunar, then it asks for my password and I put that in, then hit enter.
It says: "thunar: Failed to initialize Xfconf: Error spawning command line ?dbus-launch -autolaunch=(lots of #s) --binary-syntax --close-stderr?: Child process exited with code 1
No protocol specifiedUnable to init server: Could not connect: Connection refused
(thunar:1234*) Gtk-WARNING **: 123:12:12:123: cannot open display: :0"
I didn't include the actual numbers for security reasons.
Did I do something wrong? Did I mispel sudo?
You are best off using command line programs, when it comes to graphical ones it's a bit hit and miss as you found out.
Huh?
So I want to modify the geoclue.info file and I need to do this with a command line in order to overwrite it? I've tried with Thunar and gpedit and I'm getting nowhee.
I can't modify my own device properties? The OS will deny permission and I can't chage it?
RE: How to Save Read Only Files, Questions on Location - by lovepine88 - 06-10-2021, 12:06 PM
Exclamation How to play AMR files? anonymous 4 2,403 09-20-2023, 03:48 PM
Last Post: anonymous
  How to deal with overloaded config files? jsch 1 1,125 10-02-2022, 02:46 PM
Last Post: treebeard
  New SD card won't auto-mount, will only mount as read-only 3x5co 3 1,802 07-16-2022, 02:28 PM
Last Post: dachalife
  GPS/location services don't work with Maps after Bookworm upgrade Anna 16 10,480 06-13-2022, 02:37 PM
Last Post: wibble
  Add contacts with VCF files Bouc 12 17,140 05-20-2022, 07:26 AM
Last Post: kebab
  no access to webdav files (for some apps) jsch 0 1,293 11-13-2021, 09:46 AM
Last Post: jsch
  location tracking ergo owl 39 36,217 05-13-2021, 09:38 PM
  Wrong location / place by GPS - Location Services - GNSS - Maps Anna 17 12,018 03-22-2021, 12:42 PM
Last Post: Maus
  3 Questions about jitterentropy-rngd. MtnSk8 2 3,310 03-17-2021, 09:42 PM
Last Post: MtnSk8
  Re-do First Time Setup / Location Services Setting (How?) calinb 3 4,095 01-01-2021, 08:03 PM
Last Post: calinb
