Replacing the Keyboard
(10-19-2021, 04:41 PM)fd47 Wrote: I am delighted with the work of Pinebook Pro, since April 2021 this is my main working laptop.
But recently the "down arrow" key stopped working on my Pinebook Pro..... Sad
Two questions.
1. Does it make sense to disassemble the laptop and try to repair the work? Or is it better to order a new keyboard right away?
2. Is it possible in your store https://pine64.com/product/pinebook-pro-...-keyboard/ buy a keyboard with enough at:
Russia Krasnodar Territory Novorossiysk
I am grateful in advance for the answer.
1. the keyboard is a single piece design, you can try to check out the reason and determine whether fixable. my takes is just order a new keyboard.
2. since keyboard spare park itself don't contains battery component, should able send to Russia.
Replacing the Keyboard - by gabb - 06-01-2021, 11:26 AM
RE: Replacing the Keyboard - by dsimic - 06-04-2021, 03:29 PM
RE: Replacing the Keyboard - by gabb - 06-08-2021, 07:53 AM
RE: Replacing the Keyboard - by Valenoern - 01-11-2022, 07:39 AM
RE: Replacing the Keyboard - by dsimic - 06-11-2021, 02:50 AM
RE: Replacing the Keyboard - by fd47 - 10-19-2021, 04:41 PM
RE: Replacing the Keyboard - by tllim - 10-20-2021, 06:51 PM
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,085 09-13-2023, 03:43 AM
Last Post: k3dAR
  Separate ISO keyboard for PBP Besouro 0 722 06-04-2023, 02:51 PM
Last Post: Besouro
Information Keyboard Duplicate Keypress Fix RjraymondDuplicate 0 1,125 02-17-2022, 11:52 PM
Last Post: RjraymondDuplicate
  keyboard and usb ports not working User 24565 3 2,719 02-15-2022, 10:12 AM
  power on PBP if your keyboard is dead? stozi 0 1,346 11-29-2021, 01:55 PM
Last Post: stozi
  Replacement scissor switches (ANSI keyboard)? zackw 3 3,876 08-09-2021, 09:20 PM
  Replacing the camera? lfourquaux 1 2,264 05-26-2021, 08:24 AM
  Some keyboard keys not working oddsocks 10 10,888 04-20-2021, 08:33 AM
Last Post: dsimic
  Spare parts / keyboard mbreese 2 4,268 01-07-2021, 07:40 AM
Last Post: dsimic
  How easy is it to add donor keyboard and trackpad? ENV 3 5,175 11-12-2020, 07:51 AM
Last Post: Kaythe
