Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else?
This is great t4_4t-- thanks for that tip about checking dmesg to see if the kernel params "took". Turns out I had been using the wrong syntax.
In arbian-config, after going to System --> Boot envs, I added the line
extraargs=libata.force=1.5G
(no quotes or anything-- just exactly like that), which apparently edits the /boot/armbianEnv.txt file (found these details at https://forum.armbian.com/topic/13457-ke...arameters/). After saving and restarting, dmesg shows
daffy@rockpro64:~$ dmesg | grep limit
[    3.163820] ata1: FORCE: PHY spd limit set to 1.5Gbps
[    3.163836] ata2: FORCE: PHY spd limit set to 1.5Gbps
"$ cat /proc/cmdline" now also shows that the libata.force param was applied at boot.
This is amazing! I am writing big files to my data drive and it is not failing for the first time in months! Thanks again so much.
RE: Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? - by daffy - 05-20-2021, 08:58 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 691 03-25-2024, 12:12 PM
  RK3399 PCIe enumeration jhadd 0 320 01-31-2024, 08:56 AM
Last Post: jhadd
  yocto for RockPro64 Fide 1 785 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,744 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,992 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 84,556 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 632 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 1,027 03-12-2023, 06:55 PM
Last Post: quixoticgeek
Question nand-sata-install on RAID-1 array ARMandHammer 1 940 02-12-2023, 03:10 AM
Last Post: igorp
  RockPro64 boot questions misterc 3 1,699 01-13-2023, 06:21 PM
Last Post: misterc
