Won't boot - Failed to read Who-Am-I register
(05-12-2021, 04:04 PM)Frankie Wrote: Hi,
If you flash an OS to an SD card then the phone will boot from that, you can use the OS that your phone came with or try one of the others. I like Mobian.
You could also flash Jump-drive to an SD card and flash an OS onto the eMMC.
Thank you for replying Smile
Yes, I am aware of those facts. I just want to know why this happens since it seems most users don't have this problem. I suspect it has something to do with login credentials ( Failed to read Who-Am-I register ) ?   I provided the phone with my name and a pin code/password.  I skipped connecting to wifi initially but after the setup I connected anyway and it worked. I couldn't find a progress bar during updating so I repeatedly swiped the side screen which has a progress bar in it that moved during updating. So I didn't left the phone to drop into sleep mode. Then the popup message asking for a reboot appeared, I selected reboot and since then the problem persists.  Then event has a number followed by 'iio iio device2' followed by the message. Sometimes it says 'device2' and sometimes 'device3'.
I wanted to go with Ubuntu Touch anyway and I flashed it to a micro sd. It boots very well. Apart from the problems regarding battery status and cameras (which I was aware of before installing) it boots pretty fine. The browser is working surprisingly smooth in comparison of what I saw ever before. Didn't try my sim card yet and haven't found a way to install Firefox ( I definitely want to use it ) yet.  I'm going to try Libertine ( the Ubuntu Touch native classic app store ? ) soon and see what gives.
The main problem on Ubuntu Touch is now that it won't come back from locked mode, it just gives me a slightly lit black screen.  I have searched for power saving options but found only the amount of time before auto locking to be changed.
I have done a first update on the system using sudo apt-get update followed by sudo apt-get upgrade and it seemed successful. Am I supposed to use this method on Ubuntu Touch ?  Smile
I'm very excited though to finally have the phone and Ubuntu to play around with. As I am very 'persistant' I AM going to turn this into my daily driver eventually.
Hope the phone will work, the browser already does pretty fine. Hope to get some apps working too and certainly hope to get a quick fix or workaround for the sleep mode (locked mode) bug.
RE: Won't boot - Failed to read Who-Am-I register - by nocargo - 05-13-2021, 02:06 AM
  Pinephone boot. Richy_T 4 193 05-06-2024, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 950 05-03-2024, 10:09 AM
Last Post: laserpyramid
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 317 04-02-2024, 11:50 AM
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,420 08-28-2023, 11:38 AM
Last Post: fxc
  Pinephone won't boot. spha 12 3,008 08-20-2023, 02:44 AM
Last Post: spha
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,548 05-10-2023, 03:31 AM
Last Post: fxc
  UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant) megous 182 247,657 03-05-2023, 11:04 AM
Last Post: Eugo
  Device Unable To Read MicroSD Card _radv_ 19 6,489 02-18-2023, 02:01 PM
Last Post: _radv_
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 5,467 02-03-2023, 01:27 AM
Last Post: dante404
  no sdcard boot and manjaro update failed Gwen 3 1,489 11-27-2022, 07:56 AM
Last Post: fxc
