Mobian: 2 week as main phone
(05-09-2021, 11:52 AM)steves Wrote: 4. Some sites send me to a "install our app" page, but of course, this phone can't run it. Issue being the site won't let me use it on the phone without the app. I think I can make a site work by finding the setting to disable mobile pages, but I would only want that for specific sites, not all of them.
6. Alarms don't work if the phone is asleep at the time it's suppose to go off.
4.) That's because the user agent is set to Android. You can use a firefox extension to change your user agent to a desktop system (or you could also do it manually, but that's not so practical). There are many extensions for this, I use User Agent-Switcher. Since extension's tool bar pop ups are not really usable on the Pinephone, I just set a desktop user agent once and then activate/deactivate the extension when needed. There probably are extensions where you can configure this per site also (best do the configuration on an external screen).
6.) Another often recommended option for this is wake-mobile.
Mobian: 2 week as main phone - by steves - 05-09-2021, 11:52 AM
RE: Mobian: 2 week as main phone - by steves - 05-09-2021, 12:40 PM
Mobian: 2 week as main phone - by vongillus - 05-09-2021, 02:27 PM
RE: Mobian: 2 week as main phone - by steves - 05-09-2021, 05:07 PM
RE: Mobian: 2 week as main phone - by kqlnut - 05-10-2021, 01:18 AM
RE: Mobian: 2 week as main phone - by Avatars - 05-10-2021, 07:01 AM
RE: Mobian: 2 week as main phone - by steves - 05-10-2021, 05:31 PM
RE: Mobian: 2 week as main phone - by steves - 05-16-2021, 06:44 PM
RE: Mobian: 2 week as main phone - by wibble - 05-18-2021, 10:29 AM
RE: Mobian: 2 week as main phone - by vortex - 05-18-2021, 11:55 AM
  Mobian-Kicksecure? 3460p 0 4 33 minutes ago
Last Post: 3460p
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 27 3,151 05-17-2024, 07:58 AM
Last Post: treebeard
  atinout binaries for mobian/debian? NeutralGrey 2 198 05-13-2024, 02:42 PM
Last Post: Gumur
  Mobian repository status henrythemouse 16 9,280 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 224 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,258 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,947 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 702 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,286 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,983 07-09-2023, 01:37 AM
Last Post: vusra
