Recommended distro?
The gray screen maybe is related to that one bug that happens when you reboot, it's not initializing the screen correctly, usually. In that case it is easier to always power cycle instead of reboot.
Other booting issues could come from the version of uboot installed on the eMMC or SD card. I also use an NVMe SSD inside for the OS with uboot and "/boot" on the eMMC.
Muted audio – have a check in alsamixer, press F6 to select the sound card, there are multiple controls that all affect the volume, also very important is to have the stereo polarity on either "R invert" or "L invert" because the speakers are wired incorrectly inside the computer.
Touchpad – I'm using a hacked keyboard and touchpad firmware that improves the touchpad a lot, but this is something that may or may not work great, look for posts on this topic.
As for distro, I'm using Manjaro ARM KDE like Pine64 recommends.
Recommended distro? - by djhnsn - 05-07-2021, 03:07 PM
RE: Recommended distro? - by moonwalkers - 05-07-2021, 06:16 PM
RE: Recommended distro? - by slyecho - 05-14-2021, 02:03 PM
  which distro + DE are you using these days on the Pinebook Pro? halogen 26 23,299 02-23-2022, 07:55 AM
Last Post: user18130814200115
  Manjaro Gnome on Pinebook Pro Review! - My New Favourite Pinebook Pro Distro! ImmyChan 0 1,315 02-18-2022, 12:59 PM
Last Post: ImmyChan
  Live distro GloriousCoffee 1 2,369 01-16-2021, 03:47 PM
  Best Gnome distro for PBP? Upokupo 2 4,316 11-26-2020, 11:51 AM
Last Post: clover
  Which distro for reasonable audio? brentashley 3 4,162 06-11-2020, 10:42 PM
Last Post: xmixahlx
  Better (than default Debian/MATE) Linux distro? mspohr 34 36,114 06-11-2020, 01:34 PM
Last Post: s3rvant
  gcc v7.1 or higher distro? Manjaro have it? mgrabenstein 3 4,061 05-26-2020, 10:57 AM
Last Post: xmixahlx
  Linux distro for Pinebook Pro where Suspend works appdev46 6 8,822 03-29-2020, 10:03 AM
Last Post: xmixahlx
  Best distro with xfce jorgeortiz 3 3,845 01-09-2020, 10:36 PM
