longsleep installed headers for dkms usage
I tried to build the realtek bluetooth driver by checking out the github for my version and applying the config.gz before running make modules and it still thinks the version is different.  Can you supply a kernel headers tarball for use with dkms?
I have fixed up the Makefile (I think) and created a dkms.conf file to allow for automatic module compilation but it complains about symbol versions not being identical.
ubuntu@fjords:~$ cat /usr/src/rtk_btusb-v0.8/Makefile
FW_DIR    := /lib/firmware/rtk_bt
MDL_DIR    := /lib/modules/$(shell uname -r)
DRV_DIR    := $(MDL_DIR)/kernel/drivers/bluetooth
ifneq ($(KERNELRELEASE),)
    obj-m := rtk_btusb.o
    KVER := $(KERNELRELEASE)
    KDIR := /lib/modules/$(KVER)/build
else
    PWD := $(shell pwd)
    KVER := $(shell uname -r)
endif
all:
    $(MAKE) -C $(KDIR) M=$(PWD) modules
clean:
    rm -rf *.o *.mod.c *.mod.o *.ko *.symvers *.order *.a
install:
    mkdir -p $(FW_DIR)
    cp -f rlt8723a_chip_b_cut_bt40_fw_asic_rom_patch-svn8511-0x0020342E-20121105-LINUX_USB.bin $(FW_DIR)/rtk8723a.bin
    cp -f rtl8723a_config.bin $(FW_DIR)/.
    cp -f rtk_btusb.ko $(DRV_DIR)/rtk_btusb.ko
    depmod -a $(KVER)
    @echo "install rtk_btusb success!"
uninstall:
    rm -f $(DRV_DIR)/rtk_btusb.ko
    dumped -a $(KVER)
    rm -f $(FW_DIR)/rtk8723a.bin
    echo "uninstall rtk_btusb success!"
ubuntu@fjords:~$ cat /usr/src/rtk_btusb-v0.8/dkms.conf
MAKE="make all
INCLUDEDIR=/lib/modules/$kernelver/build/include"
MAKE_smp="make SMP=1 all
DEST_MODULE_LOCATION="/kernel/drivers/bluetooth/rtk_btusb"
PACKAGE_NAME="rtk_btusb"
PACKAGE_VERSION="v0.8"
REMAKE_INITRD="no"
MODULE_NAME="rtk_btusb.o"
CLEAN="make clean"
Of course I might just be using the wrong driver for the Pine64, I was basing it off the wlan driver.
longsleep installed headers for dkms usage - by Faye - 06-14-2016, 04:18 PM
  DKMS on kernel 3.10.107-pine64 obrienmd 5 8,665 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 3,647 12-09-2017, 08:14 AM
Last Post: incoherent
  [How-To] Make PINE 64 with Ubuntu Xenial Longsleep build crunch BOINC Tasks moisesmcardona 3 8,131 07-27-2016, 01:16 PM
Last Post: NexusDude
  How to enable XDCMP on longsleep Xubuntu? melao 6 8,749 06-23-2016, 05:58 AM
Last Post: baldrob
Rainbow Longsleep magic ! Lutinmalin 6 9,187 06-08-2016, 05:54 PM
Last Post: texadactyl
