PinePhone Beta Edition will not boot from MicroSD card
Good and bad news. I can reproduce your error.
I was playing with the microSD extension cable https://pine64.com/product/pinephone-mic...46c16e2e66
It worked fine but after removing it and booting from eMMC my data SD card was not mounting at boot. If I did a 'sudo mount -a' it would mount. If I slid it out and back in it would mount.
I then tried a SD card with an OS on it. I get the same error you do over the serial console.
U-Boot SPL 2020.10-3 (Dec 03 2020 - 06:43:18 +0000)
DRAM: 2048 MiB
Trying to boot from MMC1
MMC: no card present
spl: mmc init failed with error: -123
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
The microSD extender damaged the pins in some way. The upside is that using the microSD extender I can boot off a SD card. So it must have bent the pins too flat or something. It is a tight fit.
I am going to do some more testing on the data SD card without the extender. To see if it is reliable or if the connection is intermittent and I will have to leave the extender attached for it to work reliably.
RE: PinePhone Beta Edition will not boot from MicroSD card - by 8bit - 05-06-2021, 11:33 AM
  my pinephone melted norayr 6 927 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,100 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 723 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 358 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,855 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 56,087 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,410 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 1,015 10-23-2023, 02:49 AM
Last Post: Uturn
  No calls in or out on beta IsaiahSp 0 692 09-28-2023, 10:44 PM
Last Post: IsaiahSp
  PinePhone Keyboard KJ6OHG 11 8,170 08-23-2023, 03:25 AM
Last Post: Kali
