Synchronizing: How do you sync / synchronize Calendar and Contacts with your desktop?
I have found the problem: In order to make Gnome Contacts / Calendar share their entries with Nextcloud, one has to go to Settings/Change Address Book and select the Nextcloud-Calendar in Gnome Contacts -- and do the same when adding a new entry in Calendar.
So I guess I can mark the issue as solved now. In my brief experience, the  simplest way to synchronise contacts and dates between the Pinephone and a desktop computer is to
  • install Ubuntu Server in Virtualbox and set up Nextcloud (which is easy and can be quickly done, there are loads of video tutorials)
  • go to Settings/Online Accounts/Nextcloud on the Pinephone, add the server name etc and choose calendar/contacts and do the same on the computer.
  • make sure one selects the Nextcloud address book and calendar in Gnome Contacts / Calendar (see above).
Now all entries should be synchonised and remain available when offline.
RE: Synchronizing: How do you sync / synchronize Calendar and Contacts with your desktop? - by Anna - 04-22-2021, 02:42 AM
  Has anyone got briar-desktop running on mobian? vusra 5 3,116 06-19-2023, 03:02 PM
Last Post: vusra
  Nextcloud Calendar and Contacts mark1250 3 1,473 12-29-2022, 07:27 PM
Last Post: mark1250
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,209 09-30-2022, 08:53 PM
Last Post: treebeard
  Sending Pinephone SMS from Desktop biketool 5 3,049 09-13-2022, 01:46 PM
Last Post: anonymous
  Telegram not as desktop app user641 0 820 08-05-2022, 08:45 AM
Last Post: user641
  Anyone tried Signal Desktop ragreenburg 20 14,574 05-23-2022, 04:41 AM
Last Post: Anna
  Add contacts with VCF files Bouc 12 17,100 05-20-2022, 07:26 AM
Last Post: kebab
  Deleting telephone contacts Emilio 4 2,652 02-18-2022, 05:43 PM
  Software update missing on desktop MikeMan 1 1,492 01-27-2022, 06:10 AM
Last Post: bcnaz
  Changing Desktop Environments? Ferriah 14 8,841 01-20-2022, 06:58 AM
