PineTab Pro?
(03-25-2021, 07:03 AM)tophneal Wrote: There's an issue with trying to use the rk3399 from the PBP in place of the a64 for the tab, that Pine has already gone through when trying to make a hardware upgrade path for the original pinebook: the rk3399 gets hot. the pbp is able to help manage dissipating this heat using the lower panel of the laptop body. The tab is plastic, it can't do the same thing as the pbp. A major reason pinebook users dont have an rk3399 upgrade option is bc Pine wasn't able to source a thin enough heat sink that could effectively cool the CPU and not cause damage to the plastic body.
in summary: don't hold your breath for an rk3399 pinetab, bc heat.
It also worth noting that Pine doesn't produce devices with the same mentality as large manufacturers. Pine focuses on hardware stability. So it may be another 2-3yrs before Pine deems another board worthy/capable for use in consumer-type devices.
why not make a Pinetab Pro with a metal back then?
PineTab Pro? - by sdeneefe - 03-25-2021, 12:24 AM
RE: PineTab Pro? - by barray - 03-25-2021, 02:53 AM
RE: PineTab Pro? - by tophneal - 03-25-2021, 07:03 AM
RE: PineTab Pro? - by dieselnutjob - 04-18-2021, 07:15 AM
RE: PineTab Pro? - by barray - 03-25-2021, 01:52 PM
RE: PineTab Pro? - by xalius - 03-28-2021, 07:49 AM
RE: PineTab Pro? - by barray - 04-18-2021, 10:58 AM
RE: PineTab Pro? - by Renfrow - 01-17-2022, 05:52 PM
RE: PineTab Pro? - by tophneal - 01-18-2022, 08:54 AM
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 8,060 02-28-2024, 05:03 AM
Last Post: Surehand53
Wink Screen protector for PineTab 2 vatin 0 558 11-18-2023, 01:31 AM
Last Post: vatin
  PineTab 2 (arm64) thoughts and questions acruhl 7 3,024 09-01-2023, 01:13 PM
Last Post: acruhl
  PineTab 2 Dead Screen Kramey 16 4,962 08-12-2023, 05:44 PM
Last Post: Kramey
  pinetab 2 not booting ajhiii070 5 1,911 08-07-2023, 01:46 PM
Last Post: r.aliaskarov
  does the pinetab "just worK"? averageconsumer445 19 4,804 07-15-2023, 10:31 AM
Last Post: dachalife
  Pinetab-V shipping Status? jfstepha 6 2,483 07-12-2023, 03:23 PM
Last Post: ChromaticHamster
  No WiFi or Ethernet on vanilla PineTab 2 from the factory? SmittyWerbenyegermanjenson 6 2,377 06-06-2023, 05:26 PM
Last Post: fxc
Star Looking for a Pinetab [EU] Glenn 2 2,677 01-24-2023, 06:12 PM
Last Post: Louis
  Looking to buy a PineTab Yair22 2 2,550 01-24-2023, 06:10 PM
Last Post: Louis
