USB Wireless Drivers with Longsleep Linux Kernel
(06-14-2016, 03:37 PM)CaptainZalo Wrote: I just used a vanilla debian distro with longsleep 101 kernel and did a 'sudo apt-get install linux-firmware'. It got my NetGear USB wifi dongle and my old dlink dongle running after a reboot. Did you try it?
Unless you have a very close relationship with your current linux-installation, you might want to consider reimaging the microsd-card with a current debian build and use the scripts in /usr/local/sbin to update uboot and kernel first, enlarge sd-card and then do a 'sudo apt-get update' before you install linux-firmware package.
It takes about an hour if you have a decent broadband connection (mine is 30/10 and it took 50 minutes).
Thanks Zalo. I might just do that. Sorry if this is a silly question, is the Debian distro headless or does it have the GUI? I like the headless distros and was hoping to stay with that.
RE: USB Wireless Drivers with Longsleep Linux Kernel - by jacobscarter - 06-14-2016, 08:00 PM
  +LTS/SOPINE Compilation procedure for U-Boot and Linux for pineA64 LTS. danpurprakash@gmail.com 1 4,208 06-05-2019, 11:50 PM
Last Post: igorp
  Frustrations with Wifi, VNC, Longsleep, etc. NexusDude 1 3,757 06-05-2019, 11:43 PM
Last Post: igorp
  Pine Board using linux stuck during boot sequence ktaragorn 0 2,844 03-23-2019, 04:06 AM
Last Post: ktaragorn
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 4,065 04-16-2018, 03:09 PM
Last Post: Rocklobster
Question Mali driver on linux? jamiechang917 8 11,573 03-04-2018, 03:01 PM
Last Post: Brian Beuken
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 648,598 01-31-2018, 11:58 AM
Last Post: Luke
  How to add kernel modules to Ubuntu 16.04 on PINE64+ Taiki Bessho 1 3,909 04-12-2017, 10:01 PM
Last Post: MarkHaysHarris777
  config error installing XML-RPC on longsleep Ubuntu tinkertom 2 4,737 02-22-2017, 06:50 AM
  linux mint fra0hf 9 10,942 10-29-2016, 11:41 AM
Last Post: jkmooney
Rainbow Ubuntu with Android Kernel JasperBrown 5 8,224 07-05-2016, 06:49 AM
Last Post: xalius
