Warning, 5.5mm barrel-style power cables
(03-02-2021, 07:20 PM)tllim Wrote:
(02-26-2021, 02:26 AM)biketool Wrote: I let someone look at my pinecil, they grabbed a standard 5.5mm 12v barrel-style power cable for the bench power supply assuming the pinecil used that standard and did the old push&twist to force it in.
After a few seconds of effort my associate had a stupid look on their face holding the connector cable but the center pin from the pinecil was jammed tight into the barrel connector.
Fortunately I was able to re-insert the pin and solder the broken power line back together, though certainly not as strong against a similar attack it works again over USB C (obviously) and the repaired barrel power port too so all is good.
Pinecil DC Jack is 5525 type which means 5.5OD 2.5mm ID, don't force jam the 5521 plug. The 2.5mm ID stick is too large for 2.1mm ID hole.
Read the Pinecil label, clearly stated 5525 type
That person breaks stuff, but IMHO worth posting the warning not as a complaint but as 5521 is common and plenty of stuff breakers out there will not read or understand the label.
RE: Warning, 5.5mm barrel-style power cables - by biketool - 03-03-2021, 08:13 AM
  Connecting a power supply to the Pinecil jon_bondy 1 471 02-29-2024, 07:37 PM
Last Post: Okedokey
  Best power supply? naviathan 4 4,862 02-29-2024, 07:33 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 900 01-31-2024, 12:34 AM
Last Post: suga7
  Asus laptop power supply can also power Pinecil biketool 9 8,542 11-17-2023, 12:57 PM
Last Post: killingmesmalls
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,395 10-09-2023, 10:10 PM
Last Post: clemon79
  PD-EPR support and power rating over USB Joey_bikefast 1 1,462 11-05-2022, 01:32 PM
Last Post: River
  Warning: Don't try T12 tips csiwek 4 6,459 11-05-2022, 01:19 PM
Last Post: River
  Will this power supply work? 4.5mm -> 5.5mm conversion? TB12GOAT 0 1,670 02-19-2022, 08:06 AM
Last Post: TB12GOAT
  Pinecil Power Supply with Removable Cables Recommendations moriel5 1 2,612 02-08-2022, 09:50 PM
Last Post: moriel5
  Dead short on the power input of the Pinecil m42uko 7 8,330 04-05-2021, 02:25 PM
