Installing and tweaking Chromium on Mobian and Arch
(02-27-2021, 10:40 AM)Zebulon Walton Wrote:
(02-27-2021, 08:03 AM)kqlnut Wrote: scale-to-fit works with the app ID which is not neccessarily the command name of the app. It's possible that for Chromium the app ID might be org.chromium.Chromium or something like that. Try the steps described here and see if that works. Those steps are for Arch Phosh, but I believe scale-to-fit works the same way on all Phosh distributions.
Doing the following returns no info:
WAYLAND_DEBUG=client
flatpak run org.chromium.Chromium |& grep app_id
Also tried it with WAYLAND_DEBUG=1 with the same result. I see in the link there's a global setting to scale all apps but I don't know if that will have some kind of undesirable side effects.
The app ID I used for the flatpak chromium.Chromium was Chromium. Case sensitive.
RE: Installing and tweaking Chromium on Mobian and Arch - by C0ffeeFreak - 02-27-2021, 11:16 AM
  atinout binaries for mobian/debian? NeutralGrey 2 99 05-13-2024, 02:42 PM
Last Post: Gumur
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,782 05-09-2024, 03:08 AM
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,138 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 170 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,130 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,904 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 666 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,176 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,964 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 662 07-05-2023, 03:57 AM
Last Post: paulcarton
