Mobian Firewall from iptables to nftables
my pinephone mobian CE is installed on emmc with FDE. The Mobian Doku tells me in the chapter "Firewall", that the current technology would be nftables.
I installed all available updates, but when I check the installed packages, my Mobian is still based on iptables.
# apt policy nftables
    Installed: (none)
    Candidate: 0.9.8-3
# apt policy iptables
    Installed: 1.8.7-1
I received my pinephone two weeks ago and used the installer as it came with.
Do I have to flash a newer Image to start with nftables instead of iptables?
As iptables is not configured jet.
# echo -e "\nIPv4:" && iptables -nvL && echo -e "\nIPv6:" && ip6tables -nvL && echo " "
  IPv4:
    Chain INPUT  (policy ACCEPT 0 packets, 0 bytes)
    Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
    Chain OUTPUT  (policy ACCEPT 0 packets, 0 bytes)
  IPv6:
I tried to replace it, but it seems to be impossible,-
# apt -s remove --purge  iptables
  The following packages will be REMOVED:
    iptables* mobian-base* mobian-phone-base* mobian-phosh-base* mobian-phosh-extras* mobian-phosh-phone*
  0 upgraded, 0 newly installed, 6 to remove and 0 not upgraded.
as that whould remove the phones GUI as well.
In the moment it looks to me that I could just disable and mask iptables and install and enable nftables.
Did I miss some documentation? Any ideas are appreciated.
Keep well and fit,
MicSpabo
PinePhone - Mobian (bullseye) CE
Mobian Firewall from iptables to nftables - by MicSpabo - 02-22-2021, 05:48 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 24 2,417 Yesterday, 07:42 AM
Last Post: zetabeta
  Mobian repository status henrythemouse 16 8,944 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 150 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,067 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,865 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 648 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,043 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,933 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 647 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,077 06-19-2023, 03:02 PM
Last Post: vusra
