Mobian Issues
(03-01-2021, 05:28 PM)theD0ctor Wrote: I've had the same problem as well. Can't make or receive calls. When I try to dial a number, I can quickly see the screen pop up and then disappear (as if its hanging up right away), on the receiving end it just goes straight to voicemail. Texting works both ways. Cellular data kind of works, not really - issue here was for some reason the phone disables the mobile data by itself and reverts my apn setting. There is some sort of fix/troubleshoot on mobians wiki on deleting the network modules and re-adding but it didn't exactly indicate the problem I was having since texting works, I haven't tried that yet though.
I can also confirm this is a mobian issue, and not my carrier or my carrier settings. I installed Arch Linux on an sd card, booted it, put in my apn - and right away all cellular functions worked just fine, almost flawlessly actually (calling both ways, texting both ways, and data). The only thing that didn't work was if the phone went into deep sleep or suspend or w/e, then incoming calls wouldn't go through (I expected this on most distros though anyways)
Additional issue is the date and time sync, even with manually setting the date and time - it sometimes drifts off like a 20+ days on reboot. This then causes network issues, can't connect to any ip/url unless that date/time is corrected - must be a system thing? Anyways, this causes the network to not connect on both wifi and cellular
And yes I've also done a full distro upgrade, kernel is also at 5.10
Has this issue made additional progress (particularly the calling one)?
It sounds like a voLTE problem if you have data till you go to make the call. Who is your carrier? Just wondering if it is AT&T.
Mobian Issues - by Csanderson0313 - 02-15-2021, 03:40 PM
RE: Mobian Issues - by C0ffeeFreak - 02-15-2021, 04:47 PM
RE: Mobian Issues - by Csanderson0313 - 02-15-2021, 07:40 PM
RE: Mobian Issues - by Csanderson0313 - 02-16-2021, 05:04 AM
RE: Mobian Issues - by MtnSk8 - 02-16-2021, 11:16 AM
RE: Mobian Issues - by Csanderson0313 - 02-16-2021, 01:26 PM
RE: Mobian Issues - by C0ffeeFreak - 02-16-2021, 05:59 PM
RE: Mobian Issues - by dcinoz - 02-16-2021, 08:46 PM
RE: Mobian Issues - by C0ffeeFreak - 02-15-2021, 11:38 PM
RE: Mobian Issues - by dcinoz - 02-18-2021, 06:05 AM
RE: Mobian Issues - by theD0ctor - 03-01-2021, 05:28 PM
RE: Mobian Issues - by C0ffeeFreak - 03-01-2021, 05:44 PM
RE: Mobian Issues - by theD0ctor - 03-01-2021, 06:16 PM
RE: Mobian Issues - by Gribouille - 03-02-2021, 04:57 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,675 05-09-2024, 03:08 AM
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,043 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 163 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,110 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,897 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 661 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,120 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,955 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 657 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,096 06-19-2023, 03:02 PM
Last Post: vusra
