A Cure for the Moble Data Blues (KDE Community Edition)
Here's a quick script (note that it doesn't have the --append-dns so it doesn't use the operator DNS):
#!/bin/bash
COLUMNS=15
PS3="Select the action: "
options=(Mobile_on Mobile_off Data_on Data_off quit)
select opt in "${options[@]}"
do
WWAN="wwan0"
case $opt in
Mobile_on)
        ofonoctl poweron
    ofonoctl online
        sudo systemctl restart ofono ofonoctl
    sleep 5
        ofonoctl
        break
Mobile_off)
    ofonoctl offline
        ofonoctl poweroff
        ofonoctl
        break
Data_on)
        ofonoctl poweron
        ofonoctl online
        sudo ip link set dev $WWAN up
    str=$(ofonoctl wan | grep $WWAN)
    #echo "str=["$str"]"
    #if [ str == "" ]; then
            sudo ofonoctl wan --connect
    #fi
    ip_addr=$(ip a | grep $WWAN | awk '/inet / {gsub("addr:","",$2); print $2}')
    #echo "ip_addr="$ip_addr
    ip_route=$(ip r | grep $WWAN | grep default)
    #echo "ip_route="$ip_route
    sudo ip r del $ip_route
    #echo "Adding route "$ip_route" proto dhcp metric 900"
    sudo ip r add $ip_route proto dhcp metric 900
    echo "ip a:"
    ip a | grep $WWAN
    echo "ip r:"
       ip r | grep $WWAN
        break
Data_off)
    sudo ip link set dev $WWAN down
    sudo ip a del $ip_addr dev $WWAN
    echo "ip a:"
    ip a | grep $WWAN
    echo "ip r:"
        ip r | grep $WWAN
    break
quit)
        break
        exit
        echo "Invalid input."
esac
done
read -p "Press enter to exit."
Adjust / correct as required. Hopefully it works most of the time until things are fixed by the devs.
Note that the wwan0 default route has a higher metric (900) than the wifi metric (600) so wifi has priority if it is on.
Hope @neil2ball might be able to help, even though turning modem on, ofonoctl says registered, no ringing on incoming call, and no text message.
Do you reckon eg25-manager needs to be restart too?
As it stands, 1) does not work yet...
Thought the poweroff was the culprit so I removed it. Makes no difference.
Still when you do:
ofonoctl offline
you get:
Modem         Status     SIM
quectelqmi_0  Unpowered  Unknown
As soon 2) is run, running 1) gives you the registration message. Running 3) gets mobile data working. But no incoming calls or SMS / text messages....
RE: A Cure for the Moble Data Blues (KDE Community Edition) - by dcinoz - 02-25-2021, 03:42 AM
  debugging issue realted to iso image wth extra data eror penguins_rule 3 415 04-23-2024, 03:15 AM
Last Post: tapirsurfeit
  Manjaro Plasma Beta and Cellular Data Service Fred Zyphal 7 5,228 03-17-2022, 05:50 PM
Last Post: Fred Zyphal
  No incoming SMS. Outgoing SMS, calls and data working. HardwarePunk 3 3,130 11-20-2021, 12:53 AM
Last Post: HardwarePunk
  No mobile data working itwurketnet 3 2,561 10-14-2021, 09:04 AM
Last Post: itwurketnet
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 8 7,431 04-30-2021, 03:42 PM
Last Post: Timothy_Ecc
  Plasma Mobile - no data connection KNERD 9 8,868 02-25-2021, 03:44 AM
Last Post: dcinoz
  Anbox on KDE Community Edition (Manjaro) neil2ball 8 7,034 02-21-2021, 08:53 PM
Last Post: neil2ball
  Mobile Data toggle not retained after reboot Shane 0 1,472 12-23-2020, 07:42 AM
Last Post: Shane
  Todays Manjaro CE Update Broke my AT&T Data cyberbillp 4 4,090 12-14-2020, 06:39 PM
Last Post: cyberbillp
Exclamation PinePhone Manjaro Edition, does not boot vdiazroa 2 3,165 11-28-2020, 02:00 PM
Last Post: bcg7
