ARM Microsoft Teams-problems installing
I'd like to get the linux ARM version of Microsoft teams installed on my Mobian Pinephone.  I downloaded the file teams-for-linux_1.0.6_arm64.deb from https://github.com/IsmaelMartinez/teams-...x/releases and using Kings Cross I tried running
sudo dpkg -i teams-for-linux_1.0.6_arm64.deb
After unpacking the file, it outputted:
dpkg: dependency problems prevent configuration of teams-for-linux: teams-for-linux depends on libappindicator3-1; however: Package libappindicator3-1 is not installed.
dpkg: error processing package teams-for-linux (--install): dependency problems - leaving unconfigured
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for mailcap (3.68) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Errors were encountered while processing: teams-for-linux
I thought I'd be able to fix this by next running sudo apt install -f but after running this, the output noted:
The following packages will be REMOVED: teams-for-linux
0 upgraded, 0 newly installed, 1 to remove and 37 not upgraded.
1 not fully installed or removed.
After this operation, 161 MB disk space will be freed.
Do you want to continue? [Y/n]
After confirming I'm back to square one....I have the deb file but teams is not installed.
The questions I have are 1) are the commands I attempted the correct way to try to install this deb file on my Mobian pinephone. 2) is there a way I can get this work work?  If so, how?
Feedback, direction is much appreciated as I need teams on my pinephone before I can make it a daily driver.  Thanks in advance!
ARM Microsoft Teams-problems installing - by eaglebeckley - 02-01-2021, 12:17 PM
  Stability problems with 6.1 kernel Zebulon Walton 9 2,647 05-12-2023, 08:09 AM
Last Post: zetabeta
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 1,602 01-07-2023, 09:36 AM
Last Post: dcarvil
  DNS Problems with Mobile Data arno_nuehm 29 17,197 10-29-2022, 09:16 AM
Last Post: treebeard
  Problems after Tow-Boot Dinosaur1946 3 1,786 09-18-2022, 12:48 AM
Last Post: SpaggettiCoder
  Will this battery-saving script cause problems? rp3 1 1,241 08-28-2022, 02:00 PM
  Tow-boot problems and restoring uboot Zebulon Walton 15 7,811 08-14-2022, 11:09 AM
Last Post: shulamy
  Browser cog - Problems on Mobian arno_nuehm 5 3,962 02-10-2022, 03:27 PM
Last Post: pothos
  rsyslog a bad idea? Problems with ssh, openssh-server, fail2ban Anna 7 5,314 11-14-2021, 06:20 PM
Last Post: juju
  Installing Mobian --> "Resizing file system" forever Anna 13 12,987 09-09-2021, 04:26 AM
Last Post: spaetz
Sad Problems with Twinkle SIP Application, strerror_r is not available phone123 0 1,558 07-04-2021, 12:58 PM
Last Post: phone123
