Where is the Pinephone eMMc?
As a side note, here's an interesting issue that I haven't found mentioned anywhere.
After booting from a Micro SD card and writing the image to the eMMC, if you boot the phone (or laptop) again from the same SD card, it might happen that the /boot partition from the eMMC gets mounted in Linux instead of the same, correct /boot partition on the SD card.  Then, if you perform some system changes or updates that alter the contents of /boot, such as updating the kernel packages, you end up with one part of the updates applied to the wrong /boot partition.
The solution is to change the label of the /boot partition on the SD card prior to using it for subsequent boots, so the label is no longer the same as the label of the /boot partition on the eMMC.
Edit: Actually, the same can also happen to the root partition.
Where is the Pinephone eMMc? - by tgz - 01-09-2021, 01:32 AM
RE: Where is the Pinephone eMMc? - by evilbunny - 01-09-2021, 01:59 AM
RE: Where is the Pinephone eMMc? - by tgz - 01-09-2021, 02:08 AM
RE: Where is the Pinephone eMMc? - by evilbunny - 01-09-2021, 03:11 AM
RE: Where is the Pinephone eMMc? - by tgz - 01-09-2021, 09:53 AM
RE: Where is the Pinephone eMMc? - by dsimic - 01-10-2021, 10:58 AM
RE: Where is the Pinephone eMMc? - by 7horns7eyes - 02-07-2021, 01:37 AM
RE: Where is the Pinephone eMMc? - by dsimic - 02-10-2021, 12:05 AM
RE: Where is the Pinephone eMMc? - by 7horns7eyes - 02-08-2021, 12:11 AM
RE: Where is the Pinephone eMMc? - by TRS-80 - 02-10-2021, 11:12 AM
RE: Where is the Pinephone eMMc? - by dsimic - 02-10-2021, 12:26 PM
RE: Where is the Pinephone eMMc? - by TRS-80 - 02-10-2021, 02:47 PM
RE: Where is the Pinephone eMMc? - by dsimic - 02-10-2021, 06:24 PM
  emmc speed via usb? joe1 0 22 Yesterday, 08:07 PM
Last Post: joe1
  my pinephone melted norayr 6 826 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,078 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 701 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 337 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,789 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,729 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,383 11-16-2023, 05:03 AM
Last Post: DrYak
  eMMC upgrade EuvzO8 5 1,689 11-08-2023, 11:58 PM
Last Post: brken
  Pinephone frame damages Uturn 2 975 10-23-2023, 02:49 AM
Last Post: Uturn
