Ethernet through the dock?
Reading OP - I still cannot understand why you are unable to run when powered: my power is old Samsung wall wart with Pine64 pinephone red cable, so again nothing fancy! What seems to work for me is plug everything (including power) into the dongle, then plug it into the phone. I think the phone is only enumerating stuff when it first connects to the dongle as I can get USB pendrive and keyboard/mouse to work this way, but not if I hotplug them after the dongle is connected to the phone. Similarly HDMI does work on my dongle. Last, when I plug in my dongle I often get a lot of clicking and a load of ANX messages in the log: about 50% of the time things have settled after 30 seconds and all the bits I expect to work are OK. Otherwise I unplug and try again. I have been neurotic that I have a physically loose connection but in fact think it is the ANX code that can be temperamental as I have had "the clicking symptom" kick off when the phone & dongle were flat on the desk and AFAIK the only movement was the earth rotating!
And another ps on the ethernet speeds I can get. Have radically improved with a cable swap Blush  Using a cat 5e cable instead of an ever so flexible POS means the RockPro64 goes for Gigabit
[141547.178699] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
and iperf does a lot better - constrained now by the USB-C methinks?
$ iperf3 -i 10 -t 60 -c 10.42.0.44
Connecting to host 10.42.0.44, port 5201
[  5] local 10.42.0.1 port 60234 connected to 10.42.0.44 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-10.00  sec   383 MBytes   321 Mbits/sec    0    512 KBytes
[  5]  10.00-20.00  sec   382 MBytes   320 Mbits/sec    0    595 KBytes
[  5]  20.00-30.00  sec   381 MBytes   320 Mbits/sec    0    897 KBytes
[  5]  30.00-40.00  sec   361 MBytes   303 Mbits/sec    0    897 KBytes
[  5]  40.00-50.00  sec   370 MBytes   310 Mbits/sec    0    897 KBytes
[  5]  50.00-60.00  sec   372 MBytes   312 Mbits/sec    0    897 KBytes
[  5]   0.00-60.00  sec  2.20 GBytes   315 Mbits/sec    0             sender
[  5]   0.00-60.01  sec  2.19 GBytes   314 Mbits/sec                  receiver
iperf Done.
Ethernet through the dock? - by Diagon - 01-09-2021, 12:48 AM
RE: Ethernet through the dock? - by dukla2000 - 01-09-2021, 03:15 AM
RE: Ethernet through the dock? - by Diagon - 01-09-2021, 06:32 AM
RE: Ethernet through the dock? - by dukla2000 - 01-10-2021, 10:50 AM
RE: Ethernet through the dock? - by dukla2000 - 01-12-2021, 09:10 AM
RE: Ethernet through the dock? - by dukla2000 - 01-13-2021, 04:23 PM
RE: Ethernet through the dock? - by Diagon - 01-13-2021, 11:28 PM
RE: Ethernet through the dock? - by a-wai - 01-09-2021, 08:44 AM
RE: Ethernet through the dock? - by Diagon - 01-09-2021, 02:27 PM
RE: Ethernet through the dock? - by dukla2000 - 01-15-2021, 04:53 AM
RE: Ethernet through the dock? - by scholbert - 01-15-2021, 10:18 AM
RE: Ethernet through the dock? - by Diagon - 01-16-2021, 03:47 AM
RE: Ethernet through the dock? - by scholbert - 01-18-2021, 09:03 AM
RE: Ethernet through the dock? - by Diagon - 01-18-2021, 05:17 PM
RE: Ethernet through the dock? - by scholbert - 01-19-2021, 04:20 AM
RE: Ethernet through the dock? - by dukla2000 - 01-21-2021, 02:26 PM
RE: Ethernet through the dock? - by zborgerd - 01-23-2021, 09:11 PM
RE: Ethernet through the dock? - by scholbert - 01-25-2021, 09:28 AM
RE: Ethernet through the dock? - by zborgerd - 01-25-2021, 11:18 AM
RE: Ethernet through the dock? - by zborgerd - 01-25-2021, 01:05 PM
  no HDMI (DP) Output over Dock vuj 17 11,354 06-11-2022, 05:51 AM
Last Post: zltpxqhp69o2
  screen goes blank when I insert pinephone dock, or usb-a to usb-c adaptor rp3 3 3,478 01-12-2021, 05:06 AM
Last Post: rp3
  USB-C Dock and HDMI, revison 1.2 (Modded) Ersatz 5 7,662 08-05-2020, 11:57 AM
Last Post: Ersatz
