screen goes blank when I insert pinephone dock, or usb-a to usb-c adaptor
Hi, does anyone know a fix for this?
I tried plugging in my pinephone dock (with nothing in it) to my pmos ce pinephone, running mobian, and the screen goes blank. If I unplug it, the screen comes back on again.
I have never used the dock for anything previously, or changed any settings in regard to it.
I was just going to plug a usb memory stick into the dock to transfer files to and from the phone, using a file manager.
The same thing happens if I plug a memory stick into a usb-a to usb-c adaptor, then plug it into the pinephone. (the activity light on the pendrive flashes for a second or two, however)
Regards everyone!
I have a couple usb-C devices myself, and behavior is a little quirky. For a couple of them, the display turns black like you described. However, if I plug the USB-C hub in question into a charger, the display turns back on. I think it might be some weird quirk or bug concerning power draw on external devices.
You have to turn up the screen brightness before plugging in a device that drains much power.
Thank you both so much for the feedback, you were both exactly right.
When I first plug in power to my pinephone dock before inserting it into the pinephone, the screen stays on as normal, -all good!
Also, (and I probably never would have found this myself!) if I increase the brightness of the pinephone to at least 30% on the slider, the screen can still be seen to be on, though it does dim a bit.
I suppose this is actually a small bug?
I appreciate both your time in replying!
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,861 03-25-2024, 09:07 AM
Last Post: anonymous
  unofficial kali linux for pinephone help needed pinesmell 5 3,586 01-08-2024, 02:50 PM
Last Post: ERPlegend
  Screen auto-rotation sensitivity mdk 0 265 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 643 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,079 06-22-2023, 11:20 AM
Last Post: Melechtna
  Axolotl on PinePhone / Mobian arno_nuehm 219 164,369 03-26-2023, 01:49 AM
Last Post: shulamy
  PinePhone won't boot after software update jb2000 2 1,309 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,159 03-01-2023, 04:45 PM
  Lock screen question: always squeekboard tuxcall 1 1,205 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,004 01-13-2023, 03:33 AM
Last Post: mdk
