No internet access through Pinephone hot spot
I decided to try out the wifi hot spot feature since that looks like something that could be useful. Out of the box, the "Turn on Wi-Fi Hotspot" 3 dots menu item in Settings/Wi-Fi is greyed out. So I set it up via command line per the Mobian wiki :
sudo nmcli device wifi hotspot ifname wlan0 con-name Hotspot ssid Pinephone password HotspotPassword
This sets up the hot spot and connecting to it works, however there is no internet connectivity through that connection. (This is tested by pinging 8.8.8.8 so there are no name resolution issues.) Routing table on the laptop shows the default gateway as 10.42.0.1 and that pings, but nothing further out.
The phone is connected to 4G and has internet access itself. I've tried with a couple of different laptops with the same result. For test purposes firewalls on the phone and laptops are disabled. (A side effect seems to be that King's Cross terminal no longer responds to the virtual keyboard when the hot spot is enabled.) Rebooting the phone for good measure did not change the result.
Is there any other configuration that needs to be done, or is this something that is currently known not to work?
No internet access through Pinephone hot spot - by Zebulon Walton - 12-23-2020, 08:48 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,787 05-09-2024, 03:08 AM
Last Post: anonymous
  Mobile internet via cellular network mostly not working Anna 18 10,610 01-19-2024, 02:59 AM
  unofficial kali linux for pinephone help needed pinesmell 5 3,759 01-08-2024, 02:50 PM
Last Post: ERPlegend
  Axolotl on PinePhone / Mobian arno_nuehm 219 169,554 03-26-2023, 01:49 AM
Last Post: shulamy
  PinePhone won't boot after software update jb2000 2 1,394 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,292 03-01-2023, 04:45 PM
  Battery problem with a Pinephone keyboard and Mobian elode 2 2,270 12-22-2022, 07:10 PM
Last Post: acid andy
  Sending Pinephone SMS from Desktop biketool 5 3,063 09-13-2022, 01:46 PM
  [SOLVED] Lost Internet connectivity after recent update drh 3 1,950 09-11-2022, 09:24 PM
Last Post: Katsujinken
  How to get Pinetime working with Pinephone arkadione 12 7,596 08-28-2022, 12:30 PM
Last Post: Fish
