Phosh - double-tap bug, reported upstream?
(12-03-2020, 03:55 AM)Frexit Wrote:
(12-03-2020, 03:09 AM)marcih Wrote: The double-tap bug in Phosh, where you have to double-tap the numbers on the lock screen to enter them, has been known for a while, hasn't it? It's still present for me on Mobian, Phosh version 0.6.0. Has anybody figured out a way to reliably replicate it, or even better, has it been reported upstream?
Same problem here. Sometimes it's double-tap bug, others it's the lock screen -really- locked (no tap taken at all).
And that's very annoying to reboot every time.
So why there'is no option to simply disable the lock screen in the parameters, once for all ? Why forcing people to use a lock screen which doesn't work ?
I actually found that the double-tap bug persists past the lock screen into the "main menu" user interface as well (but not into other programs or squeekboard), so it would be much better to fix the bug than just work around it by disabling the lock screen.
RE: Phosh - double-tap bug, reported upstream? - by marcih - 12-03-2020, 04:18 AM
Photo Mobian with X11 without Wayland and Phosh. Manieck71 0 1,029 09-09-2023, 07:35 AM
Last Post: Manieck71
  How to disable lock screen in Phosh? lat 14 14,460 03-31-2023, 04:17 AM
Last Post: Eugo
  Fedora + Phosh for PinePhone njha 74 132,904 12-12-2022, 10:19 PM
Last Post: wcdeich4@hotmail.com
  Enable 'upcoming-events' on Mobian/Phosh Korac 3 2,295 09-14-2022, 01:19 AM
Last Post: dukla2000
  Advise: ENABLE animations before updating phosh! Otherwise freezes and crashes! dante404 5 3,341 08-18-2022, 02:03 PM
Last Post: dante404
  Phosh message notifications issue itstoughtofocus 2 2,743 08-15-2022, 06:39 AM
Last Post: nemsys
  Building an image with phosh liara 1 1,839 02-01-2022, 08:26 AM
Last Post: kqlnut
  More useful terminal key layout for phosh's squeekboard Boern 21 27,569 01-15-2022, 02:35 PM
Last Post: gilwood
  Phosh: Idles to Lockscreen Without Powering Off Display Merc 1 1,987 11-01-2021, 09:00 AM
Last Post: e1337
  Phosh - config within Settings does not save after reboot antitheos 0 1,451 09-24-2021, 04:30 PM
Last Post: antitheos
