PSA: Warning about Pinetab Quality
(11-27-2020, 09:41 AM)barray Wrote: > Current Issue: After using the Pinetab last night, I powered it off and put it up on a dresser, as I normally do.
@ImaPagan Did you leave it on charge? If so, using USB or DC barrel jack?
I also own a PineTab and have had no issues so far. I'm using mine for a few hours at a time and generally keep the battery between 50-90% (although a few times 0%). I'm using mine twice a week or so at least.
I have some experience with LiPo batteries and they tend to bloat in such a way if they are over-charged, over-discharged, charged at too high a current, discharged at too high a current, receive impact force or run at high temperatures. I would suggest to look for one of these conditions.
Thank you for your post. No, the unit was not left on the USB charging cable. I know that there was no impact force to the unit for certain unless something happened to the unit in the factory or shipping, nor has it been over charged and never has been over-discharged. The charger is a standard 2 amp phone charger that is used with other devices without issues. If using the Pinetab for normal use, such as an e-reader causes it to run at high temperatures, than that would be an issue for Pine64 to figure out. My Pinetab has had very light use.
Also, I went ahead and submitted a ticket just to let Pine64 know of the issue. I was a bit surprised that they responded, since there have been complaints about lack of responses posted to the forum. They asked me to open up the Pinetab and take some photos, which I did. There is just a slight swelling noted on the edge of the battery nearest to the CPU. To my untrained eye it doesn't seem like much, but it may have been enough to crack the display. As in my original post, I offered to send the unit back to Pine64 for them to investigate further. I will post a follow up when there is news.
PSA: Warning about Pinetab Quality - by ImaPagan - 11-26-2020, 04:31 PM
RE: PSA: Warning about Pinetab Quality - by ImaPagan - 11-27-2020, 02:25 PM
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 8,143 02-28-2024, 05:03 AM
Last Post: Surehand53
Wink Screen protector for PineTab 2 vatin 0 568 11-18-2023, 01:31 AM
Last Post: vatin
  PineTab 2 (arm64) thoughts and questions acruhl 7 3,059 09-01-2023, 01:13 PM
Last Post: acruhl
  PineTab 2 Dead Screen Kramey 16 5,018 08-12-2023, 05:44 PM
Last Post: Kramey
  pinetab 2 not booting ajhiii070 5 1,933 08-07-2023, 01:46 PM
Last Post: r.aliaskarov
  does the pinetab "just worK"? averageconsumer445 19 4,858 07-15-2023, 10:31 AM
Last Post: dachalife
  Pinetab-V shipping Status? jfstepha 6 2,512 07-12-2023, 03:23 PM
Last Post: ChromaticHamster
  No WiFi or Ethernet on vanilla PineTab 2 from the factory? SmittyWerbenyegermanjenson 6 2,392 06-06-2023, 05:26 PM
Last Post: fxc
Star Looking for a Pinetab [EU] Glenn 2 2,690 01-24-2023, 06:12 PM
Last Post: Louis
  Looking to buy a PineTab Yair22 2 2,557 01-24-2023, 06:10 PM
Last Post: Louis
