Where is Mobian. How do you REBOOT Mobian?
(02-06-2021, 04:39 PM)K_Research Wrote:
(11-15-2020, 12:13 PM)rocket2nfinity Wrote: Do NOT pull the battery on a booted Pinephone. It can corrupt the modem requiring reflash of the modem firmware. Press the power button for 10 seconds or use the restart pin on the board or the terminal if the OS is functional.
The power off button is in the top right menu of the navbar.
Have you tried Megapixel? It's getting better all the time...
I have had this Pinephone since July of 2020 and have yet to make a successful phone call, text or take a picture none of the operating systems including the one shipped with the phone can perform these simple task.
This is actually a phone, does not seem like it...
I have pulled the battery from the phone at least 50x when it becomes non responsive out of the box it locked up and had to have the battery yanked out this Phone has spent more time getting the battery removed than productive use.
Been waiting for since July of 2020 to use as a simple phone I think its time to start my BUYER BEWARE Campaign against Pine Products in general since there is no solutions and just the run around with the occasional excuse thrown in mix of confusion.
What or where is a Megapixel? https://wiki.pine64.org/wiki/PinePhone_S...anjaro_ARM
That's probably why. Try flashing the new modem firmware and upgrade to the latest mobian or manjaro phosh. I'm using it right now and calls do work both on T-mobile and Verizon. Double check to make sure your internal antenna is connected. There are two test builds in the wiki under OS that can test the hardware to make sure nothing is wrong with the hardware
Megapixel is the camera app
RE: Where is Mobian. How do you REBOOT Mobian? - by rocket2nfinity - 02-07-2021, 04:43 AM
  can i install mobian on pinephone? luofeiyu 2 1,318 10-15-2022, 07:31 AM
Last Post: user641
Sad New PinePhone Mobian Weekly Image... No Boot photon 1 1,165 09-27-2022, 07:00 AM
Last Post: olyavi
  used PinePhone Mobian CE or PineTab CelynRollins 1 1,645 01-11-2022, 06:31 AM
Last Post: collierreinhold
  Pinephone64 Mobian openvpn setup Harry27 0 1,468 04-26-2021, 09:23 AM
Last Post: Harry27
  Looking to buy a used PinePhone Mobian CE or PineTab alontra 0 1,710 03-04-2021, 06:33 AM
Last Post: alontra
  Mobian Support and bug reporting cybercrypt13 2 3,192 03-02-2021, 09:26 PM
Last Post: cybercrypt13
