[12.11.20 Update] Latest PinePhone CE Manjaro - Device Arrival & Initial Tests Thread
(11-10-2020, 02:06 AM)kern707 Wrote: Yes, power management seem to be a major issue, please refer to the last update I wrote on my original upper post about the power drain of my PinePhone at night, while the modem was (probably) in sleep mode and the charger constantly plugged-in, I woke up in the morning expecting a full charge of the battery, that was not the case - almost like a ghost was fiddling around with my phone as I was sleeping  Big Grin
* My assumption is that this is a power management issue, and not a charger or a charging block issue - since the phone is constantly losing charge even while connected through the night to a charger and sitting still on a desk with the screen turned off and nobody touching the phone, which is very strange.
My own experience so far is that: A. the phone's very power hungry, and B. it charges up very well provided the charger can supply enough current to exceed what the phone's using at that time.
I started off trying to charge it up from my PC's USB port while I was mucking around with the phone, with WiFi enabled, and looking at the Power Supply application Status I could see it was barely able to increase the charge (often going down to about, say, 0.15W). The PC USB port does a better job for charging if you just switch the phone off completely and leave it plugged in to that.
I don't know about your Apple charger but I've got a USB mains adapter that's rated up to 2 amps output and since I plugged the PinePhone into that today it's been charging much better. Right now it's up to 99%, Status: Charging (0.61W), Current limit 1.5A. It definitely helps that I've disabled mobile, WiFi and Bluetooth while I'm doing this.
I'm a kind of antisocial weirdo so I tend to leave mobile disabled most of the time unless I'm expecting a call, so if you're leaving mobile enabled overnight when you want to charge up the phone I wonder if that's why it's not charging so well. It will use up a lot of power. I'm not talking about just relying on the modem going to sleep by itself, I mean actually disabling it through the UI.
RE: [Updated] Latest PinePhone CE Manjaro - Device Arrival & Initial Tests Thread - by acid andy - 11-10-2020, 08:27 AM
  PinePhone - boot from microSD laserpyramid 7 643 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 371 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 250 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,801 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,859 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 627 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,413 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 513 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,746 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,010 12-04-2023, 02:14 AM
Last Post: Peter Gamma
