Wifi stopped working after updates
With the DST change recently, I went thru a bit of this,, check
date ; ls -l /etc/localtime (should be soft link to right tz)
if ifconfig or ip a doesn't show wlan0,, wpa_supplicant won't work, maybe try bind cmd???
sudo tee /sys/bus/i2c/drivers/es8316/{un,}bind
Wifi stopped working after updates - by pineitup - 10-28-2020, 06:33 AM
RE: Wifi stopped working after updates - by wdt - 10-29-2020, 09:56 PM
RE: Wifi stopped working after updates - by wdt - 11-02-2020, 02:53 PM
RE: Wifi stopped working after updates - by wdt - 11-05-2020, 08:27 PM
RE: Wifi stopped working after updates - by wdt - 11-07-2020, 02:59 AM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 833 07-13-2023, 01:50 PM
Last Post: PaulQ
  wifi missing some networks filip 0 613 03-11-2023, 03:21 PM
Last Post: filip
  bliuetooth not working in Armbian 22.11.1 Pinebook Pro River 0 800 12-09-2022, 04:48 PM
Last Post: River
  U-boot Updates jaredoconnor 5 2,041 11-17-2022, 04:25 PM
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 2,039 10-08-2022, 06:22 PM
  WiFi Signal Strength? B34N 1 1,233 07-22-2022, 01:35 PM
Last Post: poVoq
  Mid 2022: what is in your humble opinion the best working OS for the PinePro? walterbe 3 2,465 06-29-2022, 02:00 PM
Last Post: Chief
  wifi hotspot ip address symbol.accounting@gmail.com 1 1,923 11-07-2021, 12:58 AM
Last Post: dukla2000
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,410 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  Wifi Troubles IDEFK 17 15,086 05-24-2021, 05:03 AM
Last Post: walterbe
